Do I need to change power steering box for disc conversion
It has been sometime since I started to get all the parts together for my c20 brake conversion but I am in the final stretch... I have a Lares quick ratio steering box that I installed when I did the power steering upgrade last year, I am doing an A-arm swap (leaving stock crossmember) the donor truck is an 87 Chevy suburban 2wd 3/4 ton, Will I need to change the power steering box, if so what box?, Thanks for any input
68 GMC 2500 stepside LWB 250CI |
![]() ![]() Join Date: Jan 2015
Re: Do I need to change power steering box for disc conversion
Your Steering box should work just fine I think they are the same from 68-87 only the hose fittings O-ring vs flare fitting which makes no difference on your conversion
