Old 05-27-2016, 11:08 AM   #1
AndyBare
Drum to disc conversion
Howdy folks, working on a 67' GMC 1 ton dually truck. I know that I can do a conversion by using the control arms and spindles off of a 73-87 GMC/Chevy, I was wondering though, can i use 3/4-ton spindles and arms on my 1-ton? I'm really having trouble finding c30 stock height spindles online (not a whole lot of time to go and take them off another truck). I find c20 conversion kits much more abundant.
Thanks for the help!
Andy
AndyBare is offline   Reply With Quote
Old 05-27-2016, 11:17 AM   #2
davepl
davepl's Avatar
Re: Drum to disc conversion
That's two different questions. You ask if you can use C10 parts because C20 kits are much more common.
Which is it... do you have a good source of 3/4T parts (C20) or just half-ton stuff? I can imagine you might get away with 3/4T pieces, but not 1/2T...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-27-2016, 11:23 AM   #3
AndyBare
My bad, I fixed it. Yeah, I was just asking if I can use 3/4T parts. Has anyone done it?
Old 05-27-2016, 11:34 AM   #4
michael bustamante
michael bustamante's Avatar
i dont see why not. change the control arms, springs, spindle and steering linkage. and brake lines i dont think it would be a issue. but ive only done half tons.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-27-2016, 11:51 AM   #5
davepl
davepl's Avatar
I've only done 3/4T parts, but I did them on my longhorn frame. If I understand correctly my frame is the same as every other 133" 1T frame, so that tells me in theory that 3/4T parts bolt up and work with the 1T frame.
That's just a theory, someone with mechanical knowledge of these frames can hopefully chime in.
