Old 05-27-2016, 02:48 PM   #1
tjc
tjc's Avatar
8lug wheels
How can I run 8 lug(c30) wheels on my 68 c20 ? Do I need to change control arms , or complete front crossmember
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 05-27-2016, 08:01 PM   #2
Re: 8lug wheels
Do you mean dual wheels?
Old 05-28-2016, 08:30 AM   #3
tjc
tjc's Avatar
Re: 8lug wheels
I have a dually set up for rear, I am looking for a front suspension set up. Are the a frames on a c20 the same as c30
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 05-28-2016, 12:52 PM   #4
Alex V.
Alex V.'s Avatar
Re: 8lug wheels
As far as wheel clearance, I believe the frames are the same. Dually trucks usually utilize a wide hub spacer in front of the drum/rotor to space the deep-dish wheel away from the suspension and brakes. Not sure if this will mean a spindle swap or just rotor/drum swap to convert, though.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-29-2016, 09:59 AM   #5
tjc
tjc's Avatar
Re: 8lug wheels
Still looking for an answer: are c20 control arms/A frames the same as c30
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 05-29-2016, 10:21 AM   #6
Alex V.
Alex V.'s Avatar
Re: 8lug wheels
What year?
Alex V.
Old 05-29-2016, 01:48 PM   #7
tjc
tjc's Avatar
Re: 8lug wheels
Sorry all this is going on 68 c20 frame
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 05-31-2016, 08:33 AM   #8
tjc
tjc's Avatar
Re: 8lug wheels
Still looking for answer
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 05-31-2016, 09:38 AM   #9
Jeff's bowtie's
Re: 8lug wheels
Are you wanting to convert to disc brakes? Either way I think you have to swap spindles 71-up for disc but your a-arms should work but you will have to change upper & lower ball joints to fit the spindle if you were closer I'd give you a pair of drums and spindles off a 68 C/30 if you want to pay shipping I'll send them to you thanks Jeff
Jeff's bowtie's is offline   Reply With Quote
Old 05-31-2016, 12:51 PM   #10
tjc
tjc's Avatar
Re: 8lug wheels
Thanks Jeff.... I think I will try to find the disc brake spindles
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
