05-27-2016, 03:22 PM | #1 |
How many Amps through the temp sender circuit
Hello, I was hoping that some one has already done the research on this and knows what the amperage running through the temperature sending unit circuit is. I added an inline resistor (near the dash) to get my gauge to read correctly with the sending unit that I am using (3/8 fitting instead of standard 1/2). I have it dialed in finally, but wanted to make sure that I'm not going to burn my truck down. I have a 3/4 Watt variable resistor in-line. It is a Cermet style resistor. Anyone have any idea if this will be sufficient or is a potential issue?
05-27-2016, 05:51 PM | #2 |
Re: How many Amps through the temp sender circuit
The temp gauge draws a very small amount of current. It will not burn your truck down. If there is a direct short you have a fuse in the inst. circuit that will blow unless it the wireing has been cobbled .
05-27-2016, 11:11 PM | #3 |
Msgt USAF Ret
Ease your mind.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-27-2016, 11:14 PM | #4 |
Not sure if this will help but ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-31-2016, 10:06 AM | #5 | |
