Old 05-27-2016, 10:02 PM   #1
gpat@earthlink.net
Active Member
72 blazer lq9 swap
Need a recommendation on a wiring system 4L80 to LQ 9 4 wheel drive . Any ideas?? thanks
gpat@earthlink.net is offline   Reply With Quote
Old 05-27-2016, 10:48 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 72 blazer lq9 swap
You'll probably get a lot of differing answers on this..but I used PSI and was well pleased.
Old 05-29-2016, 09:54 AM   #3
solidaxel
solidaxel's Avatar
I have used Howell Engine Development for my harnesses and programing
Works for me !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-29-2016, 12:37 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would use a sponsoring vendor if possible !
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-01-2016, 10:03 AM   #5
TooTall
tons of diagram info on LT1swap.com
get a stock harness and modify it on your own
you can use the original fuse box with relays or make it completely stand a lone
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 06-03-2016, 05:18 PM   #6
preciador6
What do you mean by stand alone...i have a 5.3 engine with a 700 but i want a electric trans
preciador6 is offline   Reply With Quote
Old 06-04-2016, 08:21 AM   #7
TooTall
the "stand-a-lone" can refer to engine only or engine and trans with a custom fuse box and not using the factory fuse box
If you want to run the engine and the electric . . . the 700 will not work. It's all manual
your option is to find a 4L60e or keep the 700R4 and run a cable to the throttle body for the kick down.
2013 Audi Q5
Old 06-04-2016, 11:02 AM   #8
preciador6
Nice Thanks
