Old 05-28-2016, 07:39 AM   #1
GEF56
Smile Exhaust Manifold Suggestions
56 Chevy Pickup. Small Block 350. Mustang power steering rack. Any suggestions for an exhaust manifold that will allow the steering shaft connections. I don't know if the block hugger type manifold will give enough room. An old style Ram Horn Manifold. I'm already returning one set of headers that will not work. Thanks
GEF56 is offline   Reply With Quote
Old 05-28-2016, 11:34 AM   #2
Wrenchbender Ret
Re: Exhaust Manifold Suggestions
The Ramhorn manifolds with straight down out lets fit real good. That's what came on them with a V-8 engine.
Wrenchbender Ret is offline   Reply With Quote
Old 05-28-2016, 11:47 AM   #3
1952
1952's Avatar
I second the ramhorns...cast metal get the heat out and dosnt warp...I put high heat paint on them and baked them in the bbq then installed with antisieze on the studs
An object in motion will stay in motion till you run out of gas
1952 is offline   Reply With Quote
Old 05-28-2016, 12:11 PM   #4
OrrieG
OrrieG's Avatar
Ramshorn x3. Unless you are racing they flow great, are quieter than headers, will not rust out like headers and drop to miss steering stuff. Here are mine on the driver side. IF you need a little more flow the 57 Corvette 2.5" ones are reproduced for guys drag racing in the stock classes that require a stock manifold. I have always ran them with 2.5" exhaust pipes with no issues.
OrrieG is offline   Reply With Quote
Old 05-28-2016, 01:48 PM   #5
mdpaulson1
mdpaulson1's Avatar
Same set up on mine and I went with block huggers
mdpaulson1 is offline   Reply With Quote
Old 05-28-2016, 04:57 PM   #6
OldChevy1954
Very nice, clean engine compartment there ... Ram Horns should work well.
OldChevy1954 is offline   Reply With Quote
Old 05-28-2016, 08:06 PM   #7
69l46vert
69l46vert's Avatar
Not running m11 here but another vote for Corvette style center dump ram horns. They also came on 4wd trucks and chinese replacements are available new for about 40 bucks each. Headers are nice but I prefer cast iron.
1954 GMC 101-24
Converting to 4WD
Stock 54 GMC 150 frame
Dana 44 Front Dana 60 Rear
SBC350/SM465/NP205
69l46vert is offline   Reply With Quote
Old 05-29-2016, 04:49 PM   #8
solidaxel
solidaxel's Avatar
Where do I find 40.00 new ram horns 2 1/2?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-30-2016, 07:49 AM   #9
69l46vert
69l46vert's Avatar
Looks like they have gone up some since last year. This is where I got mine for 43.00 in July 2015. They're 49.65 now free shipping
http://www.ebay.com/itm/310951136962...witem=&vxp=mtr
1954 GMC 101-24
Converting to 4WD
SBC350/SM465/NP205
Old 05-30-2016, 10:09 AM   #10
solidaxel
solidaxel's Avatar
Those are 2 inch, I am looking for two and one half inch outlet
LS 3 4L70E
Old 05-30-2016, 10:54 AM   #11
69l46vert
69l46vert's Avatar
Try Speedway or maybe Zip or some other good Corvette supplier. edit: I see you have Corvettes. Mine is a 69 hence my screen name. I searched out originals for mine since it had headers when I got it. Bought Chinese aftermarket for my project truck since it's a bit of a hybrid.
115 pair not too bad for 2 1/2.
http://www.speedwaymotors.com/Corvet...air,58966.html
1954 GMC 101-24
Converting to 4WD
SBC350/SM465/NP205
Old 05-30-2016, 06:02 PM   #12
solidaxel
solidaxel's Avatar
B I N G O, Thanks
LS 3 4L70E
Old 05-31-2016, 10:55 PM   #13
bobdavis2010
I used some from a c4 corvette
bobdavis2010 is offline   Reply With Quote
Old 06-02-2016, 12:26 AM   #14
Coupeguy2001
Coupeguy2001's Avatar
Mine are from a C4 as well, 1986.
I had the smog tubes cut off, and holes welded. Painted them with barbeque paint from Home Depot. they dull out to a dark gray, like lacquer primer, and don't leak.
You have to have the pipe flanges from the corvette to make it work because the muffler shops can't get the flanges.
The left manifold had to be shaved at the head flanges on an angle to kick the header in to clear the frame.
I took 1/8" off the inside bottom, and angle milled it to clear.
I could have ground off the tubes where the bolts are and used header bolts, but every set of headers I ever had loosened up. These never loosened up on my corvette, so I went with the ugly stock look.
Better than cast, don't hold in the heat.
Sorry for the cell phone pic. It was kinda dark when I made the pic.
Coupeguy2001 is offline   Reply With Quote
Old 06-02-2016, 07:15 AM   #15
1project2many
I'm glad to see that folks are opting for the C4 manifolds. They are an under-used solution imo. The only problem I've ever seen with these manifolds is cracking where the four tubes are welded together at the union, and this is usually only found on earlier cars with high mileage.
1project2many is offline   Reply With Quote
Old 06-03-2016, 01:49 PM   #16
72Mountaineer
72Mountaineer's Avatar
Here is how I did my '53 3100, typical GM cast iron manifolds, maybe from a truck, they're everywhere. They are shaped like they were made for this.
72Mountaineer is offline   Reply With Quote
Old 06-03-2016, 04:02 PM   #17
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by 72Mountaineer View Post
Here is how I did my '53 3100, typical GM cast iron manifolds, maybe from a truck, they're everywhere. They are shaped like they were made for this...
Any chance you have part numbers for these? Or at least what years they came on GM trucks? Trucks only? You're right that they look like an ideal solution, at least for typical street engines that aren't putting out mega horsepower.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-03-2016, 08:43 PM   #18
72Mountaineer
Any good junkyard should have this type, it came on many cars/trucks of the 70s-late 80s, sorry no part numbers. I pick them up at swapmeets for $10 (sometimes less), just watch out for the cracked ones. They usually crack around the center banks.
Old 06-04-2016, 12:03 AM   #19
Dan in Pasadena
Good info, thanks. Will they all typically have those air injection ports you had to plug?
Old 06-04-2016, 09:04 AM   #20
72Mountaineer
Some do, some don't. There are many variations of these manifolds, as I said, just check very well for cracks.
Old 06-05-2016, 09:23 AM   #21
hogfarm
I bought a couple manifold that were sugested
on ebay
I have decided to return them.they aer a littler to ruff for me
hogfarm is offline   Reply With Quote
Old 06-05-2016, 10:10 AM   #22
solidaxel
solidaxel's Avatar
Those are the ones I use for the trucks that I build, but I need the ram horns for a 56 2 door BelAir I am doing
I like the ones from the trucks because they have a stiffing bar across the top of the manifold.
Weld them up, grind them smooth and Jet Coat them also
LS 3 4L70E
Old 06-09-2016, 02:12 AM   #23
Coupeguy2001
I have 2 sets of rams horns, and a set of the lower rear exit manifolds. Looking to get $150 for each pair of 57 originals, and $100 pair for the rear exit ones.
Chris 602-510-2519
Old 06-10-2016, 06:48 PM   #24
72Mountaineer
Exclamation Re: Exhaust Manifold Suggestions
I just saw a guy that owns a local vineyard and he told me he gets $50 for any of these types of manifolds all day. Holy carp!
