Old 05-28-2016, 10:19 AM   #1
CecilDunn
Exclamation HELP! My truck just quit running while driving and now won't start
Yesterday evening I'm driving and my truck seem to start running rough then just quit had a quick look over and tried to get it started no go pumps pumping plugs all look fine and getting spark when u turn it over I do notice a putting sound out of the exhaust any ideas out there
CecilDunn is offline   Reply With Quote
Old 05-28-2016, 12:44 PM   #2
61K10
61K10's Avatar
Re: HELP! My truck just quit running while driving and now won't start
need a little more info--what year tk -- what eng? how many miles on the eng?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-28-2016, 01:03 PM   #3
CecilDunn
Got it started running real rough though 62 283 sounds like it's missing at certain rpm rattles n shakes should I check compression plugs didn't look bad when it quit sounded like wasn't getting gas
Old 05-28-2016, 04:28 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Timing chain may have jumped a tooth.
66 C20 Service Truck:
Old 05-28-2016, 04:31 PM   #5
LostMy65
LostMy65's Avatar
Is it an old points distributor, or have you upgraded to HEI?
Old 05-28-2016, 04:46 PM   #6
CecilDunn
Points
Old 05-28-2016, 06:12 PM   #7
CecilDunn
Compression test ran with sad results thought I would like to look under the valve covers but I am having trouble removing those to investigate further seem to be stuck on from number years of abuse guess it's just time to replace and rebuild any thoughts?
Old 05-29-2016, 02:47 PM   #8
TopFuel1966
TopFuel1966's Avatar
If the motor is running rough and is puffing out of the exhaust I would venture to guess that a leakdown test would reveal worn/sticking/burnt exhaust valves in #7 and #8 cylinders at the very least. Depending on mileage it's probably time for a rebuild.
TopFuel1966 is offline   Reply With Quote
Old 05-29-2016, 05:59 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
With the numbers you showing.....that motor is severely worn, or all the valves are hanging open, or the rings are broken in two cylinders. I'd pull the valve covers off and do an adjustment then recheck compression. If numbers are the same then it's time to yank the motor out and see what happened inside. Did you lose oil pressure? Engine seized?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-29-2016, 07:35 PM   #10
Rodder29
Before you yank the engine, do a little bit more troubleshooting. Squirt some oil down the spark plug holes, then do another compression test, and hold the pedal to the floor as you're cranking the engine over. If the compression ratio comes up then you know you have a problem with the rings, if not then you likely have leakage past the valves.
Rodder29 is offline   Reply With Quote
Old 05-30-2016, 04:25 PM   #11
vince1
7 and 8 are across from each other right? So not a head gasket problem. Bent valves from a jumped chain? I think it is a nice opportunity to take it out and get it all cleaned up. Farmer's overhaul with just rings bearings and gaskets won't cost more than $300 or $400 but machining and all the other stuff that goes along with it would be considerably more.
vince1 is offline   Reply With Quote
