05-28-2016, 12:18 PM | #1 |
Unique method of lowering
The rear of my new (to me) '86 short bed sits low with no lowering parts installed. I've never seen this method of lowering before. What do y'all think. It appears that they were bent in a press as the bends are very straight and uniform.
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
05-28-2016, 12:38 PM | #2 |
Re: Unique method of lowering
wow...
first off im kinda surprised they havent snapped yet. second all that trouble to take the springs off and put them in a press instead of spending a little money for shackels |
05-28-2016, 01:32 PM | #3 |
I'd be pulling those off my truck ASAP.
05-28-2016, 02:08 PM | #4 |
Post Whore
Looks very much like the way it was done back in the day..when you do it on the cheap...heat it with a torch til it collapses..I've seen several done that way when I was in school..not the best idea..
05-28-2016, 02:23 PM | #5 |
It worked but I would be to nervous to ride with them.
Btw it would be very cool wall or yard art. |
05-28-2016, 03:04 PM | #6 |
Cruzzzn' Vet
Yup! torched
05-28-2016, 06:30 PM | #7 |
Pretty interesting. It does look like somebody used a press or a brake to bend them. I would be curious what that 2nd leaf does under flex. I would try to jack up just one wheel and see how it flexes or hook a trailer on it. It is probably safer than it looks. It's still a waste of time since new springs are only a couple hundred bucks.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-28-2016, 09:35 PM | #8 |
This is the best I've seen.
bagged 87 |
05-28-2016, 09:41 PM | #9 |
Does the pinion face the ground? lol
05-28-2016, 10:16 PM | #10 |
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-28-2016, 11:05 PM | #11 |
Getting Old; Going Broke
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
05-28-2016, 11:08 PM | #12 |
Post Whore
Ha ha..double shackles...priceless
05-28-2016, 11:11 PM | #13 |
Impossible to bend spring steel cold in a press. I've tried a few times. You will get a few degrees and then a violent snap of the metal. Those were torched for sure.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-28-2016, 04:41 PM | #14 |
Yes, I knew a guy that heated his leafsprings and it looked just like that. Do you still live in Wetumpka?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
