Help with brakes please
So I just got the build to the point that brakes need to be done. Installed all new brakes lines, shoes, cylinders, conversion to feint disc, dot 4. So I have disc frint, new power booster, master cylinder and proportion valve. Got brakes bled as inetructed, front are great, very strong and solid, but the rear are acting strange. There is only a small about of pressure when bleeding them. The fronts - the pressure gushes out, the rear not so much, fluid comes out clean, but not under pressure like the front. Could a vend that may be kinked a bit cause this? Or?
Thanks for your time. |
![]() Join Date: Feb 2016
Re: Help with brakes please
Is the rear rubber hose new ?
Yes, everything is brand new
Post #20 here has a diagram of your prop valve.
You need to push in and hold in the bleeder rod. It might be behind a black cap. http://67-72chevytrucks.com/vboard/s...d.php?t=543671 |
geezer#99
i really appreciate you taking the time to help me. i will try this tomorrow. it makes senses, so ill give it a shot. |
