![]() Join Date: Feb 2009
WTB - OEM and NOS parts for 1971 C/10
The steel has to be right please (ie show quality, no dents, stripped parts etc), OEM and correct.....Thank you:
1. One NOS hood spring. 2. NOS LH hood hinge, depends on rivet type. 3. Mint LH exterior door handle. 4. Two park light housings with the cable & rubber like new. 5. Mint NOS LH paint divider. FOUND THANK YOU 6. Mint NOS non-tilt shift lever: I believe the part # is 3990301. 7. Hardware for the ground strap from bed to frame. I don't know what the correct hardware ism because mine was missing. 8. Four 1/2" head tapered screws with integrated washers for mounting the cowl panel. 9. Anti-Dieseling Relay hardware. I don't know what the correct hardware is, because mine was missing. 10. Five 5/16" head tapered screws to attach the wire gutter to radiator support. FOUND THANK YOU 11. Four phillips head tapered screws with integrated washers for the glove box perimeter (i.e., glove box liner screws). Nice finish preferred. I'll take them all if nice or need be. FOUND THANK YOU 12. Blower Vent Tube for A/C. If by chance it's super then I'll take it. 13. Interested in the small parts (retainers, screws, nuts, clips etc.) for an A/C system, from the evaporator box forward. Some of those retainers are nylon. Would prefer the nylon is nice, but it doesn't have to be. 14. Center A/C vent housing (aka assembly), good condition and good teeth. I could use a nut or two for attaching the vent to it as well. These have a washer set into the nut. FOUND THANK YOU 15. One or two screws to mount the Vacuum Reservoir to the evaporator Box. These have a washer molded into the head. I don't recall head size, 3/8" I imagine. FOUND THANK YOU 16. Outer grille brackets. I only need the LH side, but I'll buy a pair if need be. FOUND THANK YOU 17. 3-6 door latch screws. These are phillips recessed-head machine screws. The threads are 5/16" x 1/2". FOUND THANK YOU 18. Jack components. I have the jack itself and the spring that holds it onto the floor. All else is missing. FOUND THANK YOU
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-08-2016 at 11:14 PM. |
Re: WTB - OEM and NOS parts for 1971 C/10
Crickets
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Add:
Door latch screws. These are phillips recessed-head machine screws. The threads are 5/16" x 1/2". Jack components. I have the jack itself and the spring that holds it onto the floor. All else is missing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-01-2016 at 10:25 PM. |
#4 | |
'71 Chevy swb fleet yellow project '64 Impala SS 409 4-speed 51K mile black/silver survivor |
I found the A/C vent but no jack pieces yet
Thanks for looking. If you're willing to part, I really don't need the center vent, just the housing and nuts. Other than that, let me know what I owe ya........
Not happy about having to look for jack parts, but that's what I get for my ignorance. Not that I chucked them. More I didn't know the what.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-02-2016 at 01:00 AM. |
![]() Join Date: Aug 2014
Do you need a leaf or coil spring jack?
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
#8 | |
Ah, didn't know there was a difference. I have leaf springs.
AWESOME...........You take paypal? I'll pay their fees. Thanks a bunch.
![]() Join Date: May 2011
I should have all the small fasteners but will be until Wednesday next week before I can look.
![]() Join Date: May 2010
This should take care of much of your list.
1st Picture, Hardware: Top row- cowl screws (black and stainless), wire gutter screws, glove box screws and latch plate, A/C vacuum reservoir screws. Second row- door latch screws, jack tool spring with hardware. 2nd, 3rd and 4th pictures: rear paint divider moldings (restored). All 3 pieces plus all but 1 or 2 of the clips. 5th picture: both grille brackets (sandblasted). Some pitting. Prices: - Hardware- free - Moldings- $40 plus shipping. - Brackets- $20 plus shipping. Jim |
#13 |
I have an NOS LH exterior door handle. $175 shipped.
#14 |
If the Op passes on paint divider, I'll take it for my truck
IT IS WHAT IT IS |
#15 | |
#16 |
#17 | |
![]() Appreciate those who set me up........Thanks.
#18 |
A bit over my budget, but thanks for the response.
#19 |
A little props to Jim "FirstOwner" - The paint dividers and retainer between them were restored to the cat's meow.
