Old 05-28-2016, 05:10 PM   #1
bmfm64
bmfm64's Avatar
4L65e swap questions
Swapped in a 5.3/4l65e to my 70 chev. Trying to figure out my speedo, cooler lines and trans linkage now.
Can you run an original speedo? Has anyone done an adapter from the VSS to a cable drive?
What trans cooler lines are you guys running?
How about you shift linkage for on the column shifting?
Pics would really help, Thanks in advance.
bmfm64 is offline   Reply With Quote
Old 05-28-2016, 07:36 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 4L65e swap questions
Locar trans linkage is what i used.
Cable-x i believe will work.
Standard trans cooler lines with barbed ends.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-31-2016, 10:11 AM   #3
bmfm64
bmfm64's Avatar
Thanks, I'll have a look at those!
Old 05-31-2016, 12:32 PM   #4
zach_carver
zach_carver's Avatar
I used Lokar column shifter linkage also, and Im using rubber transmission oil cooler lines from napa with barbed male end adapters into transmission. No need to bend and fight with metal lines.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
