Old 05-29-2016, 12:52 PM   #1
Rustyo61
Header help
Will hooker 2466hkr headers work on a 1961 ? V8 swap th350 auto and a 1987 front crossmember swap. Any help or picturesomething greatly appreciated
Rustyo61 is offline   Reply With Quote
Old 05-29-2016, 07:30 PM   #2
Rustyo61
Re: Header help
Any help
Old 05-29-2016, 09:11 PM   #3
LVPhotos
LVPhotos's Avatar
Re: Header help
Sure. Mine didn't clear clutch fork. But my motor is farther forward and up with Porterbuilt stuff.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-29-2016, 09:15 PM   #4
LVPhotos
LVPhotos's Avatar
Re: Header help
Another member plus torsion bars.
Old 05-29-2016, 09:37 PM   #5
Rustyo61
Re: Header help
Ok thanks for the info
Old 05-30-2016, 08:15 AM   #6
bosephus
bosephus's Avatar
Re: Header help
Did you find another set of headers that did clear the clutch fork? Mines a 61 with bars still in and original standard bellhousing.
bosephus is offline   Reply With Quote
Old 05-30-2016, 11:28 AM   #7
LVPhotos
LVPhotos's Avatar
Re: Header help
bosephus
The shorties work fine and ram horn one as well from Speedway Motors. I went with a hydraulic clutch bearing with new TKO 600. If Hookers were 1/2" in ether way it could clear fork.
Old 06-02-2016, 11:42 PM   #8
luvbowties
luvbowties's Avatar
Smile Re: Header help
Pretty underside--esp. exhaust system!
Sam
luvbowties is offline   Reply With Quote
Old 06-03-2016, 10:34 AM   #9
LVPhotos
LVPhotos's Avatar
Re: Header help
Sam
I bought the Pypes x pipe, extentions and some Super 40. This setup alot nicer than my shop build.
Old 06-03-2016, 12:56 PM   #10
LVPhotos
LVPhotos's Avatar
Re: Header help
This is my parts. Blue arrows is Pypes tunnel x, Green is extra header dump legs, Black polished ss header extension. Orange is one of two Flowmaster Super 40s. All stainless steel. The x is functional unlike my last set up.
