Old 05-29-2016, 07:48 PM   #1
683/4farm
disc brake conversion
Did a disc brake conversion on my 68 gmc 3/4 ton 2wd from a 84 3/4 ton crossmember,booster master and all,problem is that bleed the system and there is no air and the wheels will not move when pedal is pressed but pedal goes all the way to the floor,and ideas what this could be?
683/4farm is offline   Reply With Quote
Old 05-29-2016, 08:28 PM   #2
davischevy
davischevy's Avatar
Re: disc brake conversion
As I understand it, the brakes work, but the pedal is on the floor.
First guess would be, did you use the old actuator rod from the pedal to the booster?
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 05-29-2016, 08:30 PM   #3
683/4farm
No because they are totally different setups,and i only chaged it to this one is because the old booster was bad blowing air making truck run bad
Old 06-01-2016, 02:05 PM   #4
683/4farm
Push rod on pedal is pushing plenty of air through the master,i did notice when i pulled master back off though is fluid running out,have to think bad master?
