Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-29-2016, 09:22 PM   #1
nancyboy
WTB Flexplate
I am in need of a flexplate *(flywheel) for 66 250. switching to automatic transmission
Thanks, joe
nancyboy is offline   Reply With Quote
Old 05-29-2016, 10:04 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: WTB Flexplate
When I was looking for a flexplate, I learned there were two different sizes.
So you may want to specify which size you want.
You'll want the same size as your manual flywheel if you are going to use same starter. (14"=168 teeth--12 3/4" = 153 teeth.)
66 C20 Service Truck:
Old 05-30-2016, 06:51 PM   #3
nancyboy
Re: WTB Flexplate
Good to know.
Thank You
Old 05-30-2016, 11:17 PM   #4
Captainfab
60-66 Nut
Re: WTB Flexplate
You will not be able to use the same starter when changing from a manual trans to an automatic. The manual trans starter bolts to the bellhousing and with an automatic, the starter bolts to the block.
