Gauge Cluster Removal
Ok all,
I am trying to remove the gauge cluster in my 62 and I have disconnected all the wiring, the 5 screws holding it in. It seems to be hung up on something, but not sure what. Is there some other screws or clips that hold it in? I did see and remove some cage nut looking items on each side of the dash cluster. I definitely don't want to force it and damage the cluster or the dash. Any help would be appreciated. |
Post Whore
![]() Join Date: Mar 2013
Re: Gauge Cluster Removal
Unscrew the speedo cable and it'll fall right out.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
There's these funky spring clips around the perimeter that catch the cluster.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Chevrolet Shop Manual used specialty tool J-5742. Basically a flat screwdriver with a flat 90* hook on the end.
#7 | ||
Moderator
![]() ![]() Join Date: Aug 2011
My bad, the specialty tool was for Tilt Cab Instrument Panels. Same Panels used by GMC.
#9 | |
Cluster is out and ready for a refresh... Here is what they resemble... https://www.tomsbroncoparts.com/prod...77-ford-bronco Last edited by reed62; 05-30-2016 at 10:45 PM. Reason: adding photo of clip |
Post Whore
I was wrong as well....forgetting my GMC's design is much different. lol The GMC uses the same design from 60-66 that chevy used from 60-63 as far as the knobs. The knobs on the bottom of the dash are separate from the cluster. Then in 64-66, chevy moved the knobs to the cluster's frame....and to get that cluster out I had to removed the choke knob, windshield wiper control knob, and head light knob; then I removed the speedo cable and was able to pop it out diagonally. Pain in the rear compared to my GMC. lol But it's done.
