Old 05-30-2016, 09:10 AM   #1
hogfarm
Tranny Lines
Bulding auto trans cooling lines.dothey need to have a rubber flex joint?
hogfarm is offline   Reply With Quote
Old 05-30-2016, 10:30 AM   #2
Dave0
Re: Tranny Lines
Yes
Dave0 is offline   Reply With Quote
Old 05-30-2016, 12:21 PM   #3
DransportGarage
DransportGarage's Avatar
Re: Tranny Lines
In my opinion, no. They need a few bends so they can shrink and expand a little, preferably a couple near 90 degrees. That's the way they were made back in the day. Any rubber part of the line will be the weak link from a pressure standpoint and may deteriorate due to contact with the trans fluid.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 05-30-2016, 01:51 PM   #4
OrrieG
OrrieG's Avatar
Re: Tranny Lines
Not if you use hydraulic equipment rated hose from a place that makes them for commercial equipment like back hoes, etc. Fuel rated hose is not good enough.
OrrieG is offline   Reply With Quote
Old 05-30-2016, 02:36 PM   #5
HUSSEY
HUSSEY's Avatar
Re: Tranny Lines
Some OEMs have rubber flex lines and some don't. There's not much pressure in the trans cooler lines so I wouldn't be concerned at all with a rubber flex line. Just make sure you use a rubber line that is compatible with transmission fluid.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 05-30-2016, 07:16 PM   #6
DransportGarage
Re: Tranny Lines
Hi Orrie, it would be interesting to see if the steel was stronger, or the rated hose. I have a feeling the rated hose might win that one. They typically are good for 3000+ psi.
Bob
Old 05-30-2016, 09:19 PM   #7
_Ogre
_Ogre's Avatar
Re: Tranny Lines
not if you build them right. rarely does an oem cooler line have anything but steel
truk has all ss steel lines, i ran them down the oil pan flange straight out to the radiator
the oil pan flange is approx the center of the motor and has minimal flex
27,000 miles and that is the least of my worries
shop air compressor timer
Old 05-31-2016, 09:44 AM   #8
72Mountaineer
72Mountaineer's Avatar
Re: Tranny Lines
I did mine in all steel.
72Mountaineer is offline   Reply With Quote
Old 05-31-2016, 03:35 PM   #9
mr48chev
mr48chev's Avatar
Re: Tranny Lines
Nice job(s) there on both of those Ogre and 72Mountaineer. I'd agree that in the majority cases there is no need to put rubber lines in.
From experience the rubber line or where it connects to the steel line or the cooler is always where the leak is.
My ongoing truck projects:
Old 05-31-2016, 03:50 PM   #10
72Mountaineer
Re: Tranny Lines
We've all used rubber lines for these types of things before. If you can put a bubble flare on the steel line, go for it. It might last 10 years before anything happens, maybe never. Tranny fluid can keep the rubber in better condition than the **** gasoline we all buy today.
Old 05-31-2016, 05:54 PM   #11
dsraven
Re: Tranny Lines
I just replaced some OEM rubber hoses on a gm diesel, the rubber was rated for 300 psi. it was the crimp that gave out, not the rubber.
a rubber flex is not a bad idea or at least leave some space between tie downs for the lines to flex if going all solid.
Old 05-31-2016, 09:17 PM   #12
1project2many
Re: Tranny Lines
It's very common to see rubber / steel combination lines today. I can't begin to count how many I've seen fail. Common practice today is to use an aluminum band crimped around the hose at the steel tube. The hose usually shrinks and starts to fail.
If you are going to use all steel tubing you need to allow for flex and motion in the driveline. Typical OEM practice is to route the line along the engine/trans combination then support it somewhere near the engine mount. From that point the line is often unsupported until it connects with the radiator / trans cooler. Bending is allowed across a fairly long amount of tubing. It is also possible to create expansion or flex loops such as found on brake tubing below the firewall.
I agree that the quality of hose makes a large difference in a steel/rubber combination. So does the clamp. Norma Torro clamps (aka European Hose Clamps) are an excellent choice for a high tension clamp on a rubber line.
1project2many is offline   Reply With Quote
Old 06-01-2016, 08:50 AM   #13
hogfarm
Re: Tranny Lines
I have decided to use rubber steel combo.Today I will make an aluminum blockI can bolt to the frame across from the Tranny and conect with hydraulic hose,then from aluminum use steel to cooler.I dont have a milling machine ,so it will just take me a little longer squaring the block on my Lathe I will get pictures,Thanks for all the help
Old 06-01-2016, 06:05 PM   #14
dsraven
Re: Tranny Lines
a good hydraulic hose place could put together a hose with fittings to match the trans cooler end and also a compression fitting to fit over your steel line. that is a common fix on newer style chevy trucks with the poorly crimped trans cooler hoses. hose shops simply supply a new hose with compression fittings on each end that fit onto the old steel or aluminum lines.
Old 06-01-2016, 08:29 PM   #15
_Ogre
_Ogre's Avatar
Re: Tranny Lines
going to the frame maximizes the flex on the cooler lines
look at the routing down the oil pan flange for minimal flex
truk has no couplings or fittings other than each end of the lines
Old 06-01-2016, 09:11 PM   #16
DransportGarage
Re: Tranny Lines
X2. I'll just pull my hair out instead of commenting further.
Bob
Old 06-01-2016, 09:33 PM   #17
donandal
Re: Tranny Lines
Some valid points here from several gentlemen.
I had very little room under/near the oil pan area on my 5.3 swap into my 53 pickup so I went over to the frame. Because I expected this would involve more flexing, I made this section with braided stainless hose with a Teflon inner lining that is designed for transmission fluid. From there it was made with steel hard line and fittings.
A bit more expensive, but I didn't want to do it over....ever.
53 Chevy Pickup
donandal is offline   Reply With Quote
