Old 05-30-2016, 06:00 PM   #1
bautino95
Active Member
whats this wiring plug for?
1971 c10 402 with a/c. I found it wrapped up behind the distributer after doing a hei swap. Looks like 2 brown wires, 1 with a white strip on one side and i think a blue wire for the other side of the plug. I cant find anything unpluged and everything seems to work. Thanks
bautino95 is offline   Reply With Quote
Old 05-30-2016, 06:04 PM   #2
tdangle
tdangle's Avatar
Re: whats this wiring plug for?
AC Compressor clutch?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-30-2016, 06:11 PM   #3
bautino95
Active Member
Nice try, but no. A/c clutch has its plug on it and works. Im kind of stumped. Ive tried looking at wiring diagrams but cant find a plug end with 2 browns and a blue.
Old 05-30-2016, 06:43 PM   #4
dazza
dazza's Avatar
I think its for TCS (transmission controlled spark), emissions control connecting to your transmission, only allowing vacuum advance in high gears.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 05-30-2016, 06:49 PM   #5
bautino95
Active Member
Huh ok, I'll go look under the truck on the tranny, its a th400 btw
Old 05-30-2016, 06:54 PM   #6
bautino95
Active Member
Never mind. I just looked up what a tcs does. I guess someone deleted it and taped up the wires. I'll just tape them back up.
Old 05-30-2016, 07:14 PM   #7
dazza
dazza's Avatar
If in fact that is what they are for, they don't need to be hooked up even if you could.
