![]() Join Date: Jan 2012
Steering wheel help/?????
I have a 72 c10 and I pulled the busted up stock wheel off and wanted to add this wheel but it will not go on. It bottoms out on the column before it hits the groves. Any suggestions is it a possibility??? Any help is much appreciated.
![]() Join Date: Jun 2009
Re: Steering wheel help/?????
Looks like a 67-68 wheel.
It should fit, make sure the shaft didnt drop down in the column housing some.
Do you have a picture of the column with the wheel off? I just changed my 68 c10 wheel for a 69 rosewood Camaro wheel with a 67-68 Camaro hub. Maybe you have a hub on the column that needs to come off because the hub is built into that 67-68 wheel you are trying to put on.
This is my column with a 67-68 Camaro hub installed. My thumb is touching the hub that would have to come off if I wanted to put my 68 truck wheel back on.
#8 | |
Posted via Mobile Device |
Here is a pic without the wheel and my old wheel. Doesn't seem like the shaft slid down either.
Side view
Old wheel
If your wheels are set straight, I think you need to put the button for the horn at the 10 or 11 o'clock position instead of the 1 or 2 o'clock position it is currently in and then proceed to slide your steering wheel on in the straight forward position. At least that is the way that I had to put my 68 wheel on.
#13 |
The only way that the wheel could slide on the shaft is if the wheel was turned clockwise a quarter of a turn with the way the horn button is currently situated.
#14 | |
Does it matter if it was a 3 on the tree? Thanks again for the help. Posted via Mobile Device |
#15 |
I know there have been steering column shafts with a "Master Spline" (larger single spline than the rest) but I don't remember that being the case with these trucks though. it should fit, unless the shaft diameter is either too small or too large.... interesting......
![]() Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
