Old 05-30-2016, 10:22 PM   #1
wcorbett
Bad speedo or cable?
Now that I'm driving the truck more regularly, some age issues are popping up. Occasionally heard a a noise that was behind the dash intermittently. Driving down the road today, suddenly a high pitch squeal under my feet, speedo was bouncing at the 100 mph mark( no I wasn't actually going that fast), stopped the truck, and the speedo stayed pegged past 100. Disconnected the cable at the trans first ( no change), then disconnected behind the dash (no change). Speedo is now pegged all the way to the right. So, is the speedo toast, or can I reset it somehow and replace the cable and be good to go? Thanks for any help?
wcorbett is offline   Reply With Quote
Old 05-31-2016, 11:07 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Bad speedo or cable?
Had something similar happen in my '65 truck. Had to replace the speedo unit as it ended up snapping the needle off. Luckily I had a spare cluster.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-31-2016, 06:42 PM   #3
63burban
Chevy addict
We do it the old fashioned way and take things apart to diagnose the problem, difficult to check it out from here.
63burban is offline   Reply With Quote
Old 05-31-2016, 09:40 PM   #4
Cape Codder
Cape Codder's Avatar
Nothing can be condemed till taken apart even if it can[t go back together
Cape Codder is offline   Reply With Quote
Old 05-31-2016, 10:34 PM   #5
69chevytrucker
69chevytrucker's Avatar
check the driven gear in the trans they pile up and do funny things
69chevytrucker is offline   Reply With Quote
Old 06-01-2016, 12:13 AM   #6
jtrichard
YES TOAST .....The needle shaft has seized (Lack of lube 50...years go figure) to the main input in the speedo head it needs to be rebuilt or new mechanism
jtrichard is offline   Reply With Quote
Old 06-01-2016, 09:08 AM   #7
vince1
I think the needle is connected to a magnetic drag cup with a spring to always pull it back to zero. It has obviously gained traction from the turning piece inside it going wonky.
vince1 is offline   Reply With Quote
