Old 05-31-2016, 08:18 AM   #1
RyansToy
RyansToy's Avatar
Wheel Mount Surface Question
So yesterday I had some tires mounted to 17" steel wheels (late model donor).
I noticed I was having a hard time torquing the lug nuts. They were loose every time I went around the star...
There appears to be "dowels" protruding in 3 spots on the front drums.
The image show's holes, but mine has what appears to be dowel pins sticking out.
This image shows the locations inbetween the lugs better. They are just holes on this drum. Two wheels on the truck have features to clear these pins. Two on the back do not. I drilled the new wheels to clear them. What are they??
1968 GMC truck
910 Trim (Canadian)
127" WB
3 on the Three Trans (Saginaw SM330)
250 ci L6 Engine
HEI ignition (early 80s L6)
RyansToy is offline   Reply With Quote
Old 05-31-2016, 12:19 PM   #2
geezer#99
geezer#99's Avatar
Re: Wheel Mount Surface Question
Those 'dowels' are rivets. Used to hold the drum to the hub.
You can grind them off and tap them out (like in the pic). Then the hub is easier to remove.
You should be torqueing in the normal pattern and not round and round. Round and round never tightens up, it just stretches the studs.
Look here for tightening sequence.
https://tireguides.com/TireTips/TireDocument/2
geezer#99 is online now   Reply With Quote
Old 05-31-2016, 12:55 PM   #3
RyansToy
RyansToy's Avatar
I wasn't clear by round and round. regular X pattern, but go over twice to make sure.
My general rule of thumb is to visit the bolt an extra time after they reach the torque to make sure. Hence 2nd round...
1968 GMC truck
910 Trim (Canadian)
127" WB
250 ci L6 Engine
