05-31-2016, 02:33 PM | #1 |
700r4 taking forever to shift out of 1st gear
Hi guys, I'm having some transmission issues and I'm stumped. Ive been building my truck over the past few years and finally got it on the road. A few years ago I bought a Performance Automatic trans through summit racing. It lasted about 2 weeks before I blew up the torque converter (I'm assuming it's because I bought a cheap Converter). I pulled the pan and everything inside looked ok so I'm hoping theres isn't any further damage. I replaced the TC with one custom built by a local builder who has a really good reputation. And now for the issue! Since putting in the new TC, and hooking everything up it doesn't want to shift out of first. At first it wouldn't budge unless I was just under 5000rpm regardless of how fast or slow I tried to accelerate. I tried readjusting the TV cable and I got a bit better, would shift at 3500 rpm but no sooner even if I tried shifting manually. So then I tried disconnecting the TV cable all together and still holds until 3500 rpm before shifting. What could be causing this? Any help would be appreciated.
'80 GMC C15, still in progress... http://67-72chevytrucks.com/vboard/s...d.php?t=651276 |
05-31-2016, 06:10 PM | #2 |
Re: 700r4 taking forever to shift out of 1st gear
Sounds like a stuck throttle valve
06-01-2016, 08:39 AM | #3 |
Make sure you have the TV cable adjusted correctly, and don't leave it unhooked, rumor is that you'll destroy the trans in a short amount of time with it unhooked.
06-01-2016, 11:16 AM | #4 |
Ya I know not to leave it unhooked. I only unhooked it to see how it would shift which didn't seem to make a difference. It would still hold first until at least 3500-5000 rpm, the slam into second. Same with other gears. It wouldn't shift unless the rpms were high although it's not as noticeable. It almost seems like the TV is stuck open, but I'm not sure how likely that is. As for adjustment, I've tried adjusting it multiple times without it changing much and even tried making small changes here and there to see it it would change.
