brake hose help needed
At some point my truck was converted to disc brakes by a previous owner. I need to replace the front hoses. The earliest year that O'reilly or AutoZone has hoses for is '76. Will these work? I can't take the ones that are on now down to the store to match them because I need to drive the truck. Thanks.
CCRider
Idealy you want the same year as what ever the "donor" truck was for the swap. If they swapped the whole crossmember you should have no problem...if they mixed and matched parts no telling what you have. taking your old one to match is probably your best bet
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
