Fleetside rear wheel tubs seal ?
Hey, I'm about to reinstall the Rear wheel tubs in my '72 (Blazer) but same as a fleetside truck. Where these sealed at all from the factory between the tub and the bed floor and / or the tub and the inner bedside ?
If so what material was used? Thanks for the help. jeff.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
![]() Join Date: Jun 2009
Re: Fleetside rear wheel tubs seal ?
a seam sealer works best, you can use silicone also but do it after you paint the truck if your painting
You can buy seam sealer at eastwood supply or your local body supply shop
I use Dominion. I'm not sure if you guys could get it down there. It is much like factory stuff Doesn't harden completely where it's thicker. They have a few different colors white, light, and dark grey Pops in a caulking gun and is really easy to work with
-Cody |
![]() Join Date: May 2014
I used a good seam sealer that I bought from a local ppg store. I'm sure any decent seam sealer fro the auto parts store is fine
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
Thanks everyone. Seam sealer it is.
