Old 05-31-2016, 10:34 PM   #1
12secondnova
12secondnova's Avatar
Anyone used Mcgaughys disc brake kit with stock drum spindles?
So the front drums on Gold Digger are completely shot and Im looking for the cheapest way to go disc brakes. Im looking at this kit but Im not sure if it will work with my stock spindles. http://www.summitracing.com/parts/mmc-63157/overview/ Anyone know if I can do this? Or know of a way to put 6 lug disc brakes on on the cheap?
Heres Gold Digger btw
12secondnova is offline   Reply With Quote
Old 06-01-2016, 12:23 AM   #2
custom10nut
custom10nut's Avatar
Re: Anyone used Mcgaughys disc brake kit with stock drum spindles?
I'm watching this. I too am looking for the most economical way to put discs on the front of. Y truck
custom10nut is offline   Reply With Quote
Old 06-01-2016, 01:09 AM   #3
Onelefttoget
Try looking for scarebird classic brakes. I have used them on my 65 mustang. Will use again when I build my 69 chevy c10. http://scarebird.com/index.php?route...product_id=150
Last edited by Onelefttoget; 06-01-2016 at 01:19 AM. Reason: Found helping Web page
Onelefttoget is offline   Reply With Quote
Old 06-01-2016, 09:32 AM   #4
12secondnova
Thank you! That looks like the perfect kit for me I'll be ordering later today!
Old 06-01-2016, 10:03 AM   #5
GR8-68
GR8-68's Avatar
Understand that this kit only comes with brackets and does not include the rotor an caliper
GR8-68 is offline   Reply With Quote
Old 06-01-2016, 10:09 AM   #6
GR8-68
GR8-68's Avatar
I am converting mine to the 72 model spindle by just using 72 ball joints I bought a whole front end from a junk yard for 125.00
Old 06-01-2016, 11:42 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Make sure to save the 72 centerlink.
You will need it because the tie rods are different and centerlinks aren't reproduced.
Keith
Convert to disc brakes.
Old 06-01-2016, 11:47 AM   #8
lolife99
lolife99's Avatar
This kit requires you to purchase spindles also,...
QUOTE:
Kit includes 6-lug rotors.
Fits models with only heavy duty stock brake rotors measuring 1.25 in. thick.
Must be used with McGaughy's spindle numbers 63173, and 63174.
Keith
Old 06-01-2016, 11:48 AM   #9
lolife99
lolife99's Avatar
Also you must switch the M/C to a disc brake version and add a proportioning valve for disc brakes.
Keith
Old 06-01-2016, 11:55 AM   #10
12secondnova
Yeah i figured for that price lol but the junkyard here knows me so well that they sell me parts for little to nothing so this is definitely the more cost effective way to go for me.
Old 06-01-2016, 12:01 PM   #11
12secondnova
So im looking at their site and i see these to convert the back to disc brakes also. Does anyone know if these are the right pattern for the 12 bolt in my truck? Like was there a difference between the car and truck 12 bolt rearend axel tube flanges? https://scarebird.com/index.php?rout...product_id=146
Old 06-01-2016, 01:27 PM   #12
Shady Rascal
Shady Rascal's Avatar
That Mcgaughys kit is no where near to getting you on the road.
Beside the kit you'll need to buy spindles, swap master cylinders, get a proportioning valve, and a pair of front wheels that will clear the discs.
I'd say try to find a 73-87 front frame cut from a truck being parted out, do the suspension swap under your truck, use the entire brake lines and all from master cylinder all the way out. Then buy a pair of 6 lug rotors from ECE or CPP or wherever you choose would come out cheaper.
Shady Rascal is offline   Reply With Quote
