Old 05-31-2016, 11:26 PM   #1
jlolson
jlolson's Avatar
79 upper radiator mount
I went with a bigger radiator and the old upper mount won't fit. Are there any off the shelf solutions that will work for a radiator flush with the top of the cores support or do I need to fabricate something? I was hoping the LMC big block mount would work but I'm not sure.
Thanks in advance.
[IMG][/IMG]
[IMG][/IMG]
jlolson is offline   Reply With Quote
Old 06-01-2016, 01:41 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: 79 upper radiator mount
by looking at your set up it a 73-80 rad support tall rad like that use the big block shroud and upper support to finish it off.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-02-2016, 12:32 PM   #3
jlolson
jlolson's Avatar
Thanks for the advice guys... ordered the LMC #15. If I don't post again here that means it fits!
Unfortunately only available in Chrome FYI.
Old 06-03-2016, 12:52 AM   #4
Pontiac1976
try Classic parts , I they might still have them http://www.classicparts.com/
