06-01-2016, 07:06 AM | #1 |
Can you tell what generation LS this is?
I am going to look at this c-10 soon.It is supposed to be a 6.0.can you tell by the pic if it is and is it DBW or cable?See anything wrong here?I don't know much about LS conversions.
06-01-2016, 07:22 AM | #2 |
Re: Can you tell what generation LS this is?
any more pics of the engine?
any numbers on the heads? 317, 243 ? What year is the block or engine supposed to be out of?
1973 K5, full vert, 6" BDS lift, 35 Mickey T MTs 1984 K10, 8" lift on 35s 2004 3/4 4wd, 33s Toyo Mts, Long Tube headers, 3K multidisk 80e, tons of miles 2011 Yukon XL | Bone stock 2013 Audi Q5 |
06-01-2016, 07:45 AM | #3 |
No more pics.Owner does not know,
already restored when he bought it. |
06-01-2016, 07:46 AM | #4 |
Does motor mount location give any info?
06-01-2016, 08:00 AM | #5 |
It is very hard to tell you anything with those covers over it. 2004.5 and newer have floating pistons and better rods. 2007 started switching over to the larger square port heads vs. the cathedral ports.
Gen3 engines with the weaker rods are still pretty reliable in the 700hp range, so unless you are trying to push it beyond that I wouldn't worry about it. Keep in mind a bone stock LQ4 which is the lowest compression version of a 6.0 still makes around 400hp with no accessories like most of our engines are dynoed. |
06-01-2016, 08:01 AM | #6 |
Looks like an earlier motor by the mechanically operated throttle body, but has aluminum heads so 2001 and newer. Appears to be some good aftermarket spark plug wires but some power robbing short headers. Can't see much else with all that heat trapping plastic on top of the engine.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
06-01-2016, 08:01 AM | #7 |
Is it an aluminum block?
06-01-2016, 08:03 AM | #8 |
Keep in mind many trucks still had cable driven throttle bodies during the transition year (2004), and vans used them for years after.
Those headers are still an upgrade over the stock exhaust manifolds. |
06-01-2016, 08:16 AM | #9 |
The only true way to tell would be to pull the VIN off the block and check it, and that's only useful if the motor was never apart. What is your concern/question about the motor?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-01-2016, 09:33 AM | #10 |
I'm fairly certain it's a 3 bolt drive by cable which says it's a gen 3 engine. That throttle body won't narrow down the year though as they are commonly swapped out by guys that don't want to deal with the extra wiring.
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
06-01-2016, 10:09 AM | #11 |
I'm going to guess by the 5 pin MAF, the drive by cable TB and aluminum heads, that it's a 2001-2002 engine
Those pretty engine covers can be slapped on anything The shorty headers are nothing special, they're just like the stock manifolds
06-01-2016, 01:46 PM | #12 |
this is a helpful video made by Summit which will definitely help you. You cannot go by heads for certain (unless you REALLY trust the guy and every owner before him) as they are swapped like underwear.
https://www.youtube.com/watch?v=4oSgOB6CvsE |
06-01-2016, 05:01 PM | #13 |
He said the heads has a casting #862 and now he thinks it may be a 5.3
06-01-2016, 05:06 PM | #14 |
Can't go by heads. Most people have no clue what's under their hood. I can't tell you how many times I've seen people talk about their Ls1's only for them to pop the hood and I'm looking at a truck manifold. Lol.
