Dust cover Manual Muncie M20 or M21 mid 70's 350 engine
Some crazy way my transmission dust cover came off during a night out and now I cannot find a replacement anywhere. I even purchased the TH350/400 but those are way too big as they are for automatic transmissions. I urgently require one if someone can point me in the right direction. It bewilders me that there are no flywheel covers for mid 70 Chevy manual transmissions.
![]() Join Date: May 2014
Re: Dust cover Manual Muncie M20 or M21 mid 70's 350 engine
I'm kind of in the same boat. I just never had one and not having much luck finding one. I'll be watching this thread
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
Do you mean something like this.
Search for 'inspection plate' on their search box. http://www.4speedconversions.com/6263757-2 |
#4 | |
No unfortunately neither do I need that. It looks quite similar to the manual flywheel cover on an automatic Trans. The pic you showing I think is for the bell housing.
That cover is the same type as an auto tranny will have.
Find a pic for us. |
Sorry but it's not I bought the automatic cover TH350/400 even the guy at summit told me it wouldn't fit but I had to try. Problem is, there are many pics of the Automatic covers but I can't find any manual pic covers.
You mean like this.
http://www.ebay.com/itm/Full-Size-Ch...-/172172522847 |
#9 | |
i have a 1966 283/m21 tranny. ill look to see if the trans plate is on there and let you know.
1967custom |
That was just an example.
You need to determine exactly what bellhousing you have. Then a pan can be found. You say m20 or m21. Do you have a Car type muncie or truck type with granny gear?. |
What I know is that it's in my 64 c10 and its 5.7 350 small block with m21 transmission 4 speed. What's a granny gear?
#13 |
#14 | |
Likely called a 'granny' gear cause if you're in first, you're moving about as fast as granny can walkin'! Easy to spot as they have a shifter in the top of the tranny. Muncie's for cars have shifters on the side cover. Can you see the bellhousing number. You might need it. |
#15 |
I'm not sure, but what I think he needs is the cover for the cast iron bellhousing like this one (that is missing) I know it's the one that I need
#16 | |
#17 | ||
#18 |
Jolobo, I wonder if this is the one needed? Weird it says V8. I don't see why there would be a difference
http://www.classicparts.com/55-72-Be.../#.V1A8ucW3NA1
#19 | |
#20 |
FlameOut
I just spoke to them guess I got a guy who had a bad day ![]() |
#21 |
my shifter is on top. i think that mine will not work for a side shift tranny. sorry
1967custom |
#22 |
It,s just a standard 12 inch trk clutch bellhousing. 60 to 72 and the older pass. cars used the same or simaler set up also.[ATTACH][/ATTACH] first pic is from the rear and second from the front. there are two pieces to the cover. a flat piece that the starter goes through and the pan on the bottom.
#23 |
I like these bellhousings because you can change the clutch without removing the bellhousing or supporting the engine
#24 |
Thanks for those dimensions, Jolobo. I haven't measured mine, but sure sounds right. I went and ordered one so I'll know Monday if it's correct
#25 |
Yea I ordered also but I'm overseas right now so it will be a couple of days before I can test it. If you get yours let me know the results and I'll do vice versa when I can.
