Old 06-01-2016, 06:12 PM   #1
RodsGreen10
RodsGreen10's Avatar
Steering Wheel Adapter Rubbing?
The cover on my steering wheel adapter is rubbing on the column. What is going on I have taken it apart 3 times and still rubbing. The part my finger is point at. This isn't rocket science but I am over looking something?
RodsGreen10 is offline   Reply With Quote
Old 06-01-2016, 06:21 PM   #2
RodsGreen10
Re: Steering Wheel Adapter Rubbing?
Should I have a spring under that? I am throwing anything at the wall trying to get it to stick. This is driving crazy.
Old 06-01-2016, 06:48 PM   #3
3drburb
Maybe a tight fit washer under it before you put it on will do the trick.
3drburb is offline   Reply With Quote
Old 06-01-2016, 06:52 PM   #4
RodsGreen10
It's only rubbing on one side. The side I am pointing at.
Old 06-01-2016, 08:35 PM   #5
RodsGreen10
The only thing that has changed beside the new steering wheel is the adapter my other wheel had a grant adapter. This one has the forever sharp steering wheel adapter. So I ordered a grant adapter and see if that fixes it.
Old 06-01-2016, 09:42 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Face it off on the lathe? Couple a thou is as good as a mile. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 06-02-2016, 01:22 PM   #7
RodsGreen10
I think I found my problem
Old 06-02-2016, 01:25 PM   #8
RodsGreen10
See this big gap here. What do I need to do to push that back?
Old 06-02-2016, 02:51 PM   #9
ultrahd4me
ultrahd4me's Avatar
I think you've found the problem, I've used 3 of these wheels recently and they all had a 1/16 uniform gap around the column covers. Are the covers good and tight?
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 06-02-2016, 02:53 PM   #10
RodsGreen10
Everything is torqued to spec. This is frustrating as hell. And I am honestly lost on what needs to be done at this point.
Which covers are you speaking about?
Old 06-02-2016, 02:56 PM   #11
RodsGreen10
Did yours come with the Forever Sharp billet adapter or the grant cast aluminum style?
Old 06-02-2016, 03:11 PM   #12
ultrahd4me
ultrahd4me's Avatar
I've always bought the Forever wheel and A1 adapter as a set.
Old 06-02-2016, 03:23 PM   #13
RodsGreen10
I bought mine from forever sharp and I used what came in the kit which should be A1 adapter.
Old 06-02-2016, 03:40 PM   #14
ultrahd4me
ultrahd4me's Avatar
In this video from Forever sharp it looks like you may need to use a supplied spacer if the adapter sets down to far.
https://www.youtube.com/watch?v=02k_41kZWqI
Old 06-02-2016, 03:42 PM   #15
RodsGreen10
I got the spacer all of it but my adapter does not look like that one in the video.
Old 06-02-2016, 08:37 PM   #16
RodsGreen10
Fixed it. It was the cover in the first pic it was bent. Bent it back good to go!
Old 04-06-2019, 01:03 PM   #17
P7M89MM
P7M89MM's Avatar
Hey, I’m having the same problem. Were you able to bend it while on the column or did you take it apart?
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts
16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust
15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs
16 Malibu Response TXi
P7M89MM is offline   Reply With Quote
Old 04-06-2019, 01:13 PM   #18
layinrocker65
layinrocker65's Avatar
Surprised to see this being a problem as I have the opposite issue with my forever sharp setup. There’s about a 1/4” gap all around on mine.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 04-06-2019, 01:17 PM   #19
P7M89MM
P7M89MM's Avatar
Mine only rubs in one location on the cover. I’m wondering if I could gain more room by going to the original canceling cam. The new cancelling cam is slightly smaller. I did order another original to try. I think I’ll break my old one if I try to remove the plunger.
Old 04-06-2019, 04:40 PM   #20
P7M89MM
P7M89MM's Avatar
Decided to pull it apart. I disassembled my old cancelling cam and used that. It’s slightly bigger than what I could find in town and it pushed the adapter out just enough that it doesn’t rub anymore.
