Old 09-30-2003, 01:34 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Carb opinions
Is a 600cfm 1406 Eldebrock too big for a 350? What is usually stock for a 4-barrel, meaning cfms?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-30-2003, 01:47 PM   #2
busterwivell
That should be fine
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 09-30-2003, 02:03 PM   #3
lewi
lewi's Avatar
I put the same carb on mine and am very happy with the results. i know one of the guys at edlebrock and ask him to set me up with something that would work now and when I pump it up to 325-350 horses.
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 09-30-2003, 02:08 PM   #4
Firefighter
Does any of yours seem to run a little rich? Mine seems to at idle you can smell the raw gas smell, and I'm not sure on how to lean it out without hurting performance. I have not adjusted anything but the idle screw on it since it was new.
Yellville, Ar. USA
Old 09-30-2003, 02:28 PM   #5
smokekiki
Mike
smokekiki's Avatar
Check edelbrock's web site.I think they have instructions on how to adjust the fuel mixture.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-30-2003, 02:30 PM   #6
Firefighter
Alright I'll look and see.
Yellville, Ar. USA
Old 09-30-2003, 02:38 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
For most stock 350's a 1406 is just fine....however for some it may be a little rich or lean. If it is, it is very easy to tune them by swapping metering rods.
The stock Q-jet is rated at 750cfm......i think 600 is perfect for a stock or mild 350.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-30-2003, 02:43 PM   #8
Firefighter
Ok, cool thanks!
Yellville, Ar. USA
Old 09-30-2003, 03:49 PM   #9
RON WOODGEARD
Resident Young Old Dude !
A 600 CFM is ideal for the small block, You can as described above, tune it up or down, The Edelbrock, or Carter is far better suited for the street then the Holley, There are rods that can be changed in about 5 minutes each, that will "tune" the fuel flow into the jets. Once you look at the rods you can get a pretty good understanding how they work. These rods can be replaced with taking nothing more off then the air cleaner and a very small plate like cover on the top of the carb. if you are running a little rich, put a rod in that is a little bigger then the one in now, ( resricting fuel flow a touch) If you need more flow, then put one in that is smaller then the one you take out.(allowing more fuel to flow) Remember, you have to change two rods. One on each side of the air throat inlet. The rods are tapered, And they have different tapers, so you can adjust the flow throughout the RPM, range. MUCH more user friendly then the holley configuration for tuning..
Ron
RON WOODGEARD is offline   Reply With Quote
