Old 06-02-2016, 11:53 AM   #1
ebaby35
62' Frame swap
Hi thinking of doing a frame swap with my 62'. Ill be getting a 63' so that I have more aftermarket stuff available to me. Just wondering if anyone has any thought on doing this. From my understanding I just have to move cab mounts. I understand that by doing this that Ill have to go through a DMV process.
ebaby35 is offline   Reply With Quote
Old 06-02-2016, 12:16 PM   #2
Brad54
Brad54's Avatar
Re: 62' Frame swap
You'd be better off going with a later front cross member and dropping it onto the '62 chassis, and then find the rear end you want and put it in. You'll need to have the saddles moved on the rear, but that's easier than moving cab mounts.
You'd also need to move the bed mounting points as well--the stringers/mounts for the bed have different holes.
The bumpers will also need to be changed, because they are different too.
Clutch linkage and brake master cylinder conversion is easier on a '63-up, but that's all on the body and not the frame.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-02-2016, 01:24 PM   #3
LVPhotos
LVPhotos's Avatar
Re: 62' Frame swap
It's been said before. The x frame is more ridged and there is just as much aftermarket for the 62 frame. It seems to me it's a lack of searching. The drop spindles, brakes 5 or 6 lug and torsion bar works fine. The rear is the same, still have to modify to fit. In fact Porterbuilt has a x member for the 63 up. If that doesn't convince you.
Long to short bed would be only concern. Apparently Chevy decided that the torsion bar was a good Idea because they brought it back
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-02-2016, 09:06 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 62' Frame swap
I agree. I had no issues with my 61. The lower ball joints were pricey, but thats about it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-02-2016, 11:35 PM   #5
Captainfab
60-66 Nut
Re: 62' Frame swap
You do not have to move any cab mounts. All you have to do to bolt a '60-'62 cab to a '63-'66 frame is drill new holes in the cab floor for the front mount bolts.
Old 03-11-2018, 08:49 PM   #6
60apache
60apache's Avatar
Re: 62' Frame swap
I'm looking to possibly put a 63+ frame under my 60 simply because I cant seem to get the exhaust the way I want it because of the x in the frame. plus my frame is sagging in the rear. Thoughts?
60apache is offline   Reply With Quote
Old 03-11-2018, 09:05 PM   #7
rvrfoot
Re: 62' Frame swap
Ask Lvphotos how he did his exhaust in his frame.
rvrfoot is offline   Reply With Quote
Old 03-11-2018, 11:36 PM   #8
Macdaddy1
Re: 62' Frame swap
60Apache
I don't know if this helps or is possible but i have a 64 frame I would let go cheap.
Macdaddy1 is offline   Reply With Quote
Old 03-11-2018, 11:37 PM   #9
Captainfab
60-66 Nut
Re: 62' Frame swap
If you have the paperwork to do it legally, I wouldn't hesitate. You will have to drill holes in the can for the front cab mount bolts and move the recessed washers. Also the bed mounting points on the '60-'62 bed sills are wider than the '63-'66's. But it is a worthwhile change IMO.
Old 03-13-2018, 07:15 PM   #10
LVPhotos
LVPhotos's Avatar
Re: 62' Frame swap
I used Pypes tunnel x pipe. DUMPED at axle. Last 2 pic are another members out to back.
Old 03-13-2018, 07:19 PM   #11
LVPhotos
LVPhotos's Avatar
Re: 62' Frame swap
Few more
Old 03-16-2018, 10:51 PM   #12
60apache
60apache's Avatar
Re: 62' Frame swap
Originally Posted by Macdaddy1 View Post
60Apache
how cheap is cheap?
Old 03-16-2018, 10:53 PM   #13
60apache
60apache's Avatar
Re: 62' Frame swap
yeah but your truck probably doesn't sit as low as mine. Mine is bagged.
Old 03-17-2018, 12:58 AM   #14
LVPhotos
LVPhotos's Avatar
Re: 62' Frame swap
Mmmmmhhhhmmm
At bottom of post is my signature plus my profile pic.
Old 03-17-2018, 10:04 AM   #15
Macdaddy1
Re: 62' Frame swap
60apache
i would let it go for $250 without wheels. PM me if you are interested.
Pat
Old 03-17-2018, 10:53 AM   #16
rvrfoot
Re: 62' Frame swap
Now thats cheeeeeeeeeeeeeeeeeeeeep.
Old 03-20-2018, 10:27 PM   #17
60apache
60apache's Avatar
Re: 62' Frame swap
Few more
do you have a part number or what vehicle that x pipe goes on?
Old 03-20-2018, 10:34 PM   #18
60apache
60apache's Avatar
Re: 62' Frame swap
where did you buy your transmission crossmember?
Old 03-21-2018, 10:01 AM   #19
LVPhotos
LVPhotos's Avatar
Re: 62' Frame swap
Pypes #
http://www.jegs.com/i/PYPES/958/XVF13/10002/-1
The crossmember came with PB but same can be had elsewhere. I cut to length and welded tabs at angles.
