Old 06-02-2016, 07:18 PM   #1
asolde
asolde's Avatar
K5 Blazer Flexplate
Can I change the flex plate with the engine installed and transmission/transfer case installed? Wondering if I could slide the trans and xfer case back enough to do the job? anyone done this?
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 06-02-2016, 08:24 PM   #2
paul mora
Re: K5 Blazer Flexplate
I just did this last week on a c10 truckyou need to be sure to have a way to support engine and tranny. I removed the drive shaft fron the rear end slid thr tranny and crossmember Back leaving two extra long bolts so it is still connected to the Bloch for extra support Unbolt thr torque converter take the bolts out of the flex plate. I did remove the tranny fluid lines and shift linkage
Pulatoy
paul mora is offline   Reply With Quote
Old 06-03-2016, 08:17 AM   #3
pound41
we would get long all thread replace in the bolt holes. support everything slide it back. switch out the plate and then slide it back up and bolt it in
pound41 is offline   Reply With Quote
Old 06-03-2016, 04:02 PM   #4
asolde
asolde's Avatar
Thanks, The good news is I don't have to change the flexplate. When I changed my engine I didn't have the torque converter bolts torque up correctly. Retorque them and my vibration is gone!
