Old 06-02-2016, 08:19 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
What a complete catastrophe
So here's the deal my truck started making a winding noise this sounded like it was coming from the transmission so last weekend me and my friend did a transmission swap for a new transmission in my truck what should have been an easy swap turned into a disaster because the previous owner POS syndrome had put in a turbo 350 trans and then I guess he couldn't fight with the transmission long enough to get the bolt holes to line up on the rear crossmember so what did the idiot do? he welds the crossmember to the frame Yep transmission not coming out unless we get that crossmember out so we broke the welds and did the trans swap lo and behold fight with it enough and you can both sit in with the bolts through the holes in the frame transmission swap done problem fixed? No drove truck around still Made terrible winding sound come to find out it's the rear end ..bearing on the pinion so I had to track down a rear end for my truck as I could not afford $1,200 for a rebuild of mine well needless to say after some searching I finally found one it was already rebuilt by somebody who's in the Driveline business and does it at home for a hobby fixes these rear ends so I buy it for a 65 because my truck is a 65 anyway getting home get ready to throw in the new rear end and find out that it's not going to work right away until I can get an adjustable track bar because the previous owner it looks like through in a 62 -63 rear end and forced it to work in my 65 the track bar is a different length on that rear end then what's supposed to be in my truck it looks like the track bar is bent and so is the bolt holding it into the stock bracket the new rear end the bracket for the track bar is actually part of the pumpkin flange so my buddy Mike ordered me 1965 adjustable track bar from classic trucks as he was saying he thinks he can trust them and what they say over CPP saying that their,s is for a 63 to 70 here are some pictures to show what I'm dealing with what do you guys think?
WOLFMANmike is offline   Reply With Quote
Old 06-02-2016, 08:52 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: What a complete catastrophe
The PO of my 61 lowered the truck and the track bar was too long so it was bent to make it shorter to center the rear with the body. After I got it, I replaced it with an adjustable one with heim joints. that worked perfect. Mine had a big stud mounted to the rear. Im not sure what that tab is on the last pic.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-02-2016, 10:48 PM   #3
WOLFMANmike
i got the super track bar kit from Earlyclassic.com http://www.earlyclassic.com/fullImag...on=912-6572TBK hoping this will fix my truck and get me back on the road again
Old 06-02-2016, 11:06 PM   #4
vince1
You will still need to come up with a stud in the rear end to hold the bar. What are the 2 plates for?
vince1 is offline   Reply With Quote
Old 06-02-2016, 11:21 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
No you don't. The Super Trackbar kit mounts too the pass. side trailing arm. You don't use the stud in the axle housing.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-02-2016, 11:51 PM   #6
Captainfab
60-66 Nut
The '60-'64's all use the longer panhard bar as shown in the pic. The '65-'72's use the shorter bar that mounts to the center section.
Old 06-03-2016, 12:54 AM   #7
WOLFMANmike
Right so now that adjustable pan hard bar should fix it now right ?
Old 06-03-2016, 06:24 AM   #8
notsolo
notsolo's Avatar
YEP!...Here is a photo from "Hart Rod" shows ECE adjustable trac bar installed.
notsolo is offline   Reply With Quote
Old 06-03-2016, 10:12 AM   #9
WOLFMANmike
Hey brother thanks so much for that .... that was a huge help. Was exactly what I was looking for . You Rock ! Happy Truckin brother
Old 06-03-2016, 10:22 AM   #10
slepysal
slepysal's Avatar
I used an adjustable one from CPP on my 60 about 3 years ago
and had to shorten the bar , but other then that it worked fine
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
