Old 06-03-2016, 06:02 PM   #1
DaddyOh
DaddyOh's Avatar
Drag Link Clearance
Doing some changes on a 65 and was wondering about drag link clearance issues. After mocking everything up... and placing steering (pitman arm) in a fore/aft neutral position, the drag link clears the crossmember by 1/16" +/-. Once steering is initiated, the pitman and idler arm move, causing drag link to move away from crossmember. Since I do not have anything to compare to, what is the center/neutral clearance of the drag link on these things?
Thanks for any info
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline   Reply With Quote
