Small block Fuel pumps??
Is the only difference's in fuel pumps being the bottom inlet & outlet lines Orientation setups in which way they are pointing & is the threaded outlet all the same size. I am having a tuff time in finding a line setup that will work with my 1989 305 ci eng. from a Pont. Firebird. Most to all Catalogs only go up to 87/88 for trucks not cars. I know I am going to have to do some modification to the line closest to the carb ( its a Holley) thats a given there. any help or direction would be great, thanks.
My truck is a 68 C10 lwb coils all around |
![]() Join Date: Jan 2012
Re: Small block Fuel pumps??
Not quite sure what you're wanting, but the fuel pump specific to your '68 with a SBC should work, unless you have altered the tank and lines. Newer pumps had 3 ports ( for emissions). As long as the cam in your '89 305 has a fuel pump lobe, factory pump for a '68 small block should work fine.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
![]() Join Date: Jan 2016
I'm also not sure what you need but I just got this pump from Summit. The bottom is clockable so you can orient the in/out ports.
http://www.summitracing.com/parts/sum-250020-1b
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
#4 | |
#5 | |
Ok I think I get it. On my '67 the fuel line is 5/16" . on '80s sbc the fuel line was 3/8" . Are the fittings the same size for both????? I do not know,but if you can get that info , you should be able to buy the correct fuel line/or make one!!!
So I guess if I buy a fuel pump for a let say a 68 w/307 or 327 eng's and then I should be able to get a stock hard line for the 68 setup? I know at the carb the hard line will need to be modified for my Holley carb.
#8 | ||
"I ain't nobody, dork."
I bent my own 3/8" steel fuel lines from my mechanical pump to Holley carb.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Yes
