Need some direction on my flip kit please
Not sure what I did wrong but it does not look right to me. I bought the truck with the Belltech kit already on it just needed some POR15. so some direction would help.
Diggin The SquareLife
Re: Need some direction on my flip kit please
Looks right to me. Why u think something is wrong
Just looked liked the spring plate needed to be straight not slanted .
U bolts aren't tightened evenly.
The flip bracket has an offset hole that lines up with the center pin on the leaf springs, it should be toward the front of the truck. The u-bolt plate should have the same offset hole which also needs to be toward the front of the truck. It looks like your flip bracket is correct but your u-bolt plate is backwards. You need to remove it and spin it 180 and reinstall it.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Thanks J knight I think your right!
