Old 06-04-2016, 12:42 AM   #1
suburban99
suburban99's Avatar
Vacuum booster recommendations?
I need to put power brakes on my '62...Already have the 2 circuit master cylinder from a "78 and front end is "78 disc. Rear is Oldsmobile 12 bolt with 11"x2" drum brakes. I don't have a ton of room as my PCM for the 5.3 is mounted on the inner fender close to where the booster goes. Maybe a 7"?
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 06-04-2016, 12:55 AM   #2
blown240
blown240's Avatar
Re: Vacuum booster recommendations?
IF you have room, the dual diaphragm 8" from Pirate Jack is a good way to go. They have ones that have runs in the paint for pretty cheap. Ive had them on a couple cars, including my 61, and they work great. I have it mounted to a Captainfab bracket....
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 06-04-2016, 10:39 AM   #3
64shortbox
64shortbox's Avatar
Or if you're Cheap like me I picked up a dual diaphragm vacuum booster from a 1993 Chevy Astro Van at Pick N Pull it's about 8" in dia. and it was $23.00 but the newer Astro's use hydro boost rather than a vacuum system. Just a thought.
64shortbox is offline   Reply With Quote
Old 06-05-2016, 01:24 AM   #4
Captainfab
60-66 Nut
There is a list of compatible boosters in post #183 on page 8 of my for sale thread for my '63-'66 booster brackets. I'm not sure if that same list is in the '60-'62 standard booster bracket for sale thread, I believe it is. Are you running an auto trans or a manual trans?
Old 06-05-2016, 02:01 AM   #5
suburban99
suburban99's Avatar
Transmission is a 4L60e from the donor truck
2015 Ram 4x4 1500
1997 Boxster.
Old 06-05-2016, 02:23 AM   #6
slepysal
slepysal's Avatar
I went with an 8 inch dual unit works great and doesn't take up a lot of room
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-05-2016, 11:16 PM   #7
Captainfab
60-66 Nut
Then this is the booster bracket you will need.
http://www.67-72chevytrucks.com/vboa...49#post3479149
The list of compatible boosters is in post #70. That list also comes with every booster bracket.
Old 06-06-2016, 12:14 AM   #8
suburban99
suburban99's Avatar
Thanks guys I think I will get an s10 or blazer style as the local pick and pull is full of them. I have the donor truck's booster but it is too large...(2000 Sierra)
I be calling on the captain for a bracket...
2015 Ram 4x4 1500
1997 Boxster.
