Old 06-04-2016, 08:43 AM   #1
WarpathEngineering
WarpathEngineering's Avatar
Another bad starter?
To make a long and boring story short, I'm now on my third reman starter and the truck isn't even on the road yet. The original starter was intermittent so I replaced it. The first reman died trying to get the truck started after replacing replacing the carb, & doing a tune up. The second one died after a trip a 10 mile round trip to the muffler shop and in and out of the drive way a couple of times. Now I'm getting ready to drop in my third & am questioning what am I doing wrong. Is it possible that the Remy remans I'm getting have all been duds or am I missing something? Battery is new, cables are clean & in good shape, replaced the fusable link because it was burned up from lying across the old exhaust. All the starters sounded good when they worked and no shims were used. I'm running shorty headers, is it possible that I'm getting a lot of heat of them just idling in the driveway?
1980 GMC Sierra Grande C15 1987-1992
1988 Chevy Silverado K1500 1992-1996
1978 Chevy K5 Blazer 1998-2002
1998 GMC Sierra SL K2500 2002-2010
2007 GMC Sierra Classic 2500HD LBZ 2010-Present
1978 Chevy Silverado K20 2016-Present
WarpathEngineering is offline   Reply With Quote
Old 06-04-2016, 10:24 AM   #2
cadillac_al
Re: Another bad starter?
Do you ever test them on the bench? If they work on the bench they almost always work on the vehicle. What is yours not doing?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-04-2016, 07:07 PM   #3
WarpathEngineering
Click......nothing
Old 06-04-2016, 07:47 PM   #4
JDL
JDL's Avatar
where you getting them?
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 06-05-2016, 12:59 AM   #5
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I hate remans. Had bad ones out of the box. Chevy, Ford, Mopar, doesn't matter. Even if they test ok at the store, they can to fail start the motor when heated up. I bought a new Delco for piece of mind. What motor is this for?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 06-05-2016, 07:45 AM   #6
Dead Parrot
All bought from same store, same brand? May be a bad batch made by a hungover crew after a Chinese holiday.
Symptoms sound like intermittent brush contact. Try tapping the bearing cup next time it happens. A 3' piece of pipe lets you do this without crawling under the truck. The new brushes need a little bit of break in running. The reman place may have skipped that step to save cost.
My $22 Autozone reman starter is in its 2nd decade, 2nd 100,000 miles and 2nd set of brushes. And it sits next to a set of ceramic coated headers.
Dead Parrot is offline   Reply With Quote
Old 06-05-2016, 07:58 AM   #7
WarpathEngineering
All bought from the same store KOI autoparts, the local parts supplier before all O'Reilly's & AutoZones started moving into town. All have been Remy remans. First one was a China built starter, second was made here but rebuilt in Mexico. Third one....I didn't check. If it goes out again, I'm gonna order a New Delco or Bosch from RockAuto. Think this time I might buy a late 90's gear reduction for a 5.7....should fit on my 350.
Old 06-05-2016, 08:53 AM   #8
Jeramy
Jeramy's Avatar
im running one on mine works great. get the bolts to match it they are slightly shorter than the ones on your direct drive starter.
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 06-05-2016, 03:26 PM   #9
Justins76
Justins76's Avatar
This is what you need. You'll need 2 of the bolts 12338064
My cardomain page
Old 06-07-2016, 01:58 AM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
The best way I have found to shim a starter takes a bit of time but I have found that taking this extra time eliminates alot of headaches later on and longer starter life as well.
1. Disconnect the battery.
2. Remove flexplate dust shield from bottom of tranny.
3. Remove the starter from engine.
4. Remove starter solenoid from starter.
5. Remount starter WITHOUT the solenoid to then engine.
6. Reach up and pull back on the plunger to move the starter drive gear into the teeth of the flexplate.
7. Using a wire feeler gauge measure the gap between the tip (crest) of the tooth on the drive gear and the bottom(valley) of the teeth on the flex plate. It should be no more than .060" NOTE; A large paper clip works well for this measurement if you don't have a wire style feeler gauge
8. If it's right, put it all back together then you're good to go. However if it's too tight or too loose, then you will need to shim it.
9. If it's too tight start with a shim that's .015" thick and shim both mounting points between the starter and block then measure again. If it's too loose then shim out ONLY the outer mounting bolt to cause the starter to tilt into the block.
10. Play around with the shimming until you achieve the proper gap of .060"
whether it's by no-shim ,full shim or half shim on either bolt.
11. Once you've got it set put'er all back together and drive on.
Yes it is time consuming and tedious but you will be pleased with the end result.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
