Old 06-04-2016, 10:14 AM   #1
blazer2007
underdash wiring mess.What have you done?
I was just wondering what others have done to clean up their wiring under the dash.I was going to add some aftermarket electric gauges and looked at the mess I,ve created from stereo,air bag wiring.I was thinking of some sorta terminal bar or a small donor fuse block.
blazer2007 is offline   Reply With Quote
Old 06-04-2016, 05:14 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: underdash wiring mess.What have you done?
I replaced the unsealed ATC fuse module on my Polaris ATV with one of the Littlefuse HWB18 Metripack 280 sealed power distribution modules... They meet IP67 water intrusion standards.
They're pretty slick compact little units. You can get em with 18 & 60 positions. You can even mix ATM fuses and Mini ISO 280 relays in these and they're safe in the engine bay.
http://www.mouser.com/ds/2/240/litte...eet-756866.pdf
http://www.mouser.com/ds/2/240/Litte...B60-245787.pdf
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-05-2016, 12:54 AM   #3
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I either wrap wires with good 3m electrical tape or use flex loom.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 06-06-2016, 08:59 AM   #4
hatzie
Moderator
hatzie's Avatar
E-Tape, even good 3M stuff, will become a sticky gooey mess.
Use real glue free Harness tape or Split loom.
Old 06-06-2016, 09:33 AM   #5
blazer2007
I was thinking of some sorta terminal block or a small fuse block as I have no heater core or ducting so I thought over on the Pass. side would be a good place to put something and would be easy to get to.
Old 06-09-2016, 09:06 AM   #6
hatzie
Moderator
hatzie's Avatar
This is a complete LittleFuse HWB18 18 terminal sealed fuse block that I posted links to above. It goves you 9 ATM fuse positions... 2 terminals per fuse... Or your own mix of ATM fuses and ISO 280 relays.
It's fully sealed and uses standard off-the-shelf ATM fuses and GM Delphi Metripack 280 Female terminals and cable seals.
