Old 06-04-2016, 01:12 PM   #1
rusty71
Brake Booster Opinions
I converted my 71 to have power brakes, I'm certain I have all the pedal rods adjusted correctly, because the pedal travel and play in the pedal feel pretty good. My problem is my brake pedal is still hard. I had a new 7" single diaphragm booster on the shelf so I just used it. Do you all think it could be too small for the truck? My engine is a stock 350 and makes plenty of vacuum. With the engine off and pumping up the brake pedal, I can't hear or feel the vacuum leaking the booster. When I start the engine with the pedal pushed I didn't notice the pedal drop either. This makes me think the booster is bad rather than the rod not pushing the master cylinder piston all the way in, I didn't seem to have any trouble bleeding the brakes when I did that. Any opinions would be appreciated.
rusty71 is offline   Reply With Quote
Old 06-04-2016, 02:16 PM   #2
Rickysnickers
Re: Brake Booster Opinions
Take the vacuum line off the booster and see if the pedal is still the same. If it is, it could be the booster is bad. You could use a vacuum pump to see if the booster holds vacuum as well.
Old 06-04-2016, 02:35 PM   #3
davepl
davepl's Avatar
Cycle the pedal several times when the engine is off to make sure any residual vacuum is gone first.
Then do exactly like you did - start the truck with your foot off the brake. If it doesn't suck the pedal down ANY, then you've clearly got a bad booster or bad connection or check valve or something, but most likely the booster.
After running it pull the hose, see if there was any vacuum being held in the reserve - there should be. You'd hear/feel it when you pull out the big check valve fitting.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-04-2016, 07:54 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake Booster Opinions
I just went through this with a 8" booster and I hated it. I swapped a good 11" booster for the whole setup in 8" chrome booster and master cylinder. I hated it. The brakes felt terrible so I went back to the factory 11" and all is well now.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-05-2016, 03:33 PM   #5
rusty71
I tried those to diagnose it and the pedal feels exactly the same, still a hard pedal. I can drive the truck down the road and get it to stop its just really difficult. I want that good solid throw you through the windshield pedal. lol Even thought the booster is new I'm starting to think its bad or too small, and isn't giving me enough line pressure.
Old 06-05-2016, 03:35 PM   #6
rusty71
That's good to know! Was it just a regular single 8" diaphragm booster? Or was it the 8" dual diaphragm booster? I was considering the 8" dual diaphragm for my truck, because I like the cleaner look of the small booster, but if it doesn't work very well I won't bother buying one.
Old 06-05-2016, 04:37 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I just ordered this one in black.
http://67-72chevytrucks.com/vboard/s...d.php?t=691791
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-05-2016, 04:41 PM   #8
A1971Blazer
A1971Blazer's Avatar
I just got an 8" dual diaphragm set-up for my K5..........I haven't installed it yet because I had to make up a new rear brake line from the front coupling all the back to the rear hose and two new lines across the rear axle.
The PO had someone replace the lines and apparently they just bought two ready-flared lines that were too long. It was a twisted up, cobbled up mess with a leaky compression fitting in the mix as well.....after I got it all back together and bled out..........the brakes are working fine....
I should have the 8" set up on soon....I'll update as soon as I git 'r done....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-05-2016, 06:29 PM   #9
Dan Wales
Just went through this with a 8" booster on friends 66. He went through 2 boosters before getting a good one on the third try.
Dan
Dan Wales is offline   Reply With Quote
Old 06-09-2016, 04:08 AM   #10
rusty71
Definitely post your results with the new booster. Sounds like I may have brand new booster that's bad from everything that's been posted. I may just switch back to a full 11" booster and see what happens.
Old 06-09-2016, 07:55 AM   #11
Andy4639
Old member
Andy4639's Avatar
It was the dual one and I'm telling you you want be happy until you go with a 11". GM used them for a reason on the 1/2 ton trucks!
Old 06-09-2016, 08:45 AM   #12
Tiger Joe
FWIW I have no issues with my dual 7" booster on my truck and it works just fine
Tiger Joe is offline   Reply With Quote
Old 06-09-2016, 02:45 PM   #13
Custom 68
Custom 68's Avatar
I'm sure different brands and quality will work differently.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-10-2016, 02:50 AM   #14
rusty71
I have no doubt about that, the trial and error part sure sucks though.
Old 06-10-2016, 02:56 AM   #15
rusty71
Okay, so I just read in another thread on the forum that the brake pedal needs another hole drilled in it about an inch lower, to give the correct pedal ratio when converting a truck that didn't originally have power brakes. I have NOT done that to my truck. Has anyone else done this? Maybe this is my problem and I'm not pushing the piston in the master cylinder in all the way.
