![]() Join Date: May 2016
Center Bolt for Leaf Springs?
I have a '57 3100 Pickup.
I need the Center Bolts for my leaf springs. 2 for front. 2 for rear. Any ideas? Thanks. |
Re: Center Bolt for Leaf Springs?
Local part store. Just measure the old ones or the hole sizes and lengths and they should be able to hook you up.
Hollister Road Co.
When you change them get a rod that's the same size as the hole and stack the leaves in order, then take two C clamps the squeeze the leaves tight, remove the rod and put in the center pin and tighten it then remove the clamps. Don't over tighten it and don't try to crank the spring back together with the new center pin, cut the new pin off at about a 1/4 - 3/8" above the nut and peen over the threaded end. center pins are soft metal under grade 5 so they strip easily.
one thing I used to do was to assemble the leafs pointing is all different directions. get the bolt in loosely and then work the individual springs into the stack so they're lined up. after that then tighten up the center bolt.
I am sorry to say I don't have the old ones.
And ... aren't the Center Bolts made from some special form of steel? Is there any place (internet site) that sells them? Thanks |
![]() Join Date: Aug 2011
Yes, lot's of the sites sell them, but the local stores should have something you could use in the place of online. http://www.classicparts.com/1934-70-.../#.V1QrSGbmqP8
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
![]() Join Date: Feb 2004
The center bolt has 2 purposes - one is to line up the leaves/hold them together and the other is to help center the springpack to the axle perch. A grade 5 probably 5/16'" bolt will suffice and if needed can be shortened with a sawsall any extra threads after installed.
I measure the hole in the axle perch with the bolt head to see if the bolt head is nearly the same size --to center springs on the perch -- and if necessary even round the hex head to get a fit. The u bolts will hold everything together-- axle perch and leaf pack together. For bigger trucks it may jump to a 3/8" bolt.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Also, While your at it. This would be a good time to bevel the ends of the springs where they contact the next spring, with a angle grinder clean and paint them and place some spring liner in-between them . Doing so will improve the ride and your backside will thank you for it.
And Oreilly's carries a good assortment of center bolts , may have to wait a day or two if they have to order them in: http://www.oreillyauto.com/site/c/se...0966/C0361.oap |
Thank you EVERYONE ....
#10 | |
Hollister Road Co.
find your size here an go to a parts store and get them http://www.dormanproducts.com/c-651-...ter-bolts.aspx if you can't get it there go to any spring shop in your area they will have some for sure. |
If you can slide the axle perch on the spring pack after installed -- even after hitting a curb --you had better re-check the torque on the u bolts.
http://www.suspensionspecialists.com/tech0004.html
OK ... thanks again for that information gentlemen.
#13 |
sandblasted, painted, teflon liners, removed 2 short overloads and new center bolt (installed upsidedown for axle flip)
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#14 |
what a lot of guys do that work on springs every day, is lay each seperate leaf of the spring on the floor with the arch up, then give it a good whack with a big hammer. if it doesn't break then re-use it. if it breaks then that just saved you a head ache.
the centre bolt should be able to be sourced from any spring shop. is there a trailer repair shop nearby? napa? they can also supply new u bolts, which should be replaced when doing spring work. shop guys will tell you u bolts are single use due to stretch, like a head bolt on an engine. do like dswr says, clamp before installing the centre bolt because the steel is soft and the bolt will strip if you try to suck the spring leaves together with the bolt. cleaning, painting and installing the teflon slippers is also a great idea. |
#15 |
Anyone have a good place to get new rebound clips? All of my folded ones are shot!
#16 |
BTW, Chevy sells them also
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
#17 | |
if it was broke we replaced it, if it wasn't broke we didn't hammer it good enough for the state inspectors....
#18 | |
![]() Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
