Old 06-05-2016, 02:13 PM   #1
MARK & DUALLY
Fender Dually Question
Hi,
My driverside fender is damaged, but how can I remove this fender????
There are no bolts or not visible.
Anyone can help me out?
MARK & DUALLY is offline   Reply With Quote
Old 06-05-2016, 06:25 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Fender Dually Question
The bolts should be visible inside the dually fender, attaching to what was the pickup box outer panel. The original wheel opening was trimmed and a piece of angle reinforcement added. The bolts protrude through that angle structure.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-06-2016, 05:55 AM   #3
GM72K10
Next!
GM72K10's Avatar
Replacement before and after shots
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 06-06-2016, 04:39 PM   #4
MARK & DUALLY
OK thanks; I can do that
Old 06-07-2016, 01:04 AM   #5
bilfman
bilfman's Avatar
Sometimes the studs mounted in the Fiberglass will break free and turn . Then you have a b"@&$h of a time getting them off . Take some time to clean and spray the threads with a penetrant so they don't break out and turn in the fiberglass fender. A little patience and prep( a few sprays and a couple days to soak) will really aid the process.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 06-10-2016, 11:11 AM   #6
MARK & DUALLY
Thumbs up Re: Fender Dually Question
I will do that too....
