06-06-2016, 05:54 PM | #1 |
WTB Toolbox door
Hoping to find either an NOS, or a repairable used 67-72 style door. (If such a thing exists!)
I am restoring a truck for a customer, and just found out his NOS door is for a 73 up. He purchased a door, and a whole bunch of other NOS parts from a guy several years back. Nobody realized it was the wrong door, untill I tried to fit it last week. I found out that the 73 up doors are a little shorter in length, and have a little more curve from top to bottom, as well as a slightly larger handle. Tried searching, but so far have come up empty. Anybody have a door stashed away? I also need one used hinge. Thanks for any help you may be able to give!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-06-2016, 10:29 PM | #2 |
Born Psycho
Re: WTB Toolbox door
i haven't seen an N.O.S. door in several years, i bought the last one i found for $500.00 and just recently found N.O.S. hinges from a fellow board member-MINE ARE NOT FOR SALE . try vintage chevy truck out here in fremont ca. (510)651-5874, he aint cheap but usually has some nice parts, he used to have an N.O.S. door but i believe he sold it. give him a shot and tell him i sent you.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-06-2016, 11:58 PM | #3 |
you can reskin the door , buy a front lower bedside repair panel from lmc and cut and break form the door skin you can do it with time and patience,also use a good sharp putty knife and hammer to gently open up the hem folds around the door and be careful measuring your id deminsions. also cut out the latch out in a square piece with plenty of good metal left around it from the original piece mount that to the back piece witha bolt that size of hole for temporary while you measure for the latch to mount in the front skin, when correct fitting is completed tach patch in being careful not to warp it , the back piece should be sand blasted and repaired with plastic body filler and plastic netting, use plenty of good rust protection paint on inner and outer pieces, when all is ready to go back together carefuly fold the break hims down over back piece .
06-07-2016, 09:07 AM | #4 |
Thanks Jerry. I will check it out.
Rusty, a reskin is my backup plan. I still need to find a door with a solid jamb area, as this one is plenty rusted. Thanks!
06-07-2016, 04:46 PM | #5 |
Equal opportunity joke ofender
I have this one. It had a patch put in by someone prior to me getting it. I found a rust free one right after I bought this one so i have no use for it. $150 shipped. Don't have the lock or key for it. I can sand the rest of the paint off if you want to see it better. The metal patch they put in was not put in flush with the og metal, I was going to cut the welds and bring it flush.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
06-07-2016, 09:44 PM | #6 |
Thanks for the offer Richard. That one looks about the same as the one that I have now. Hoping to find one without cancer in the jamb area. I have a couple of leads to check out. I will hold out for a bit. You actually found a rust free one?!!!
06-08-2016, 06:49 AM | #7 |
No problem, just thought I would offer. I did find one rust free but it does have a few dents in the face that will need to be taken care of.
Richard
06-11-2016, 08:52 PM | #8 |
If I remember right I saw a guy selling one up in Belle Fourche on Rapid City craigslist.
ps - Cheers from Rapid City! |
06-23-2016, 09:51 AM | #9 |
Active Member
I have this one $225 shipped. ppw/f mo
06-23-2016, 09:57 AM | #10 |
Active Member
Would also trade even-up for complete 8pc set '72 402 A/C brackets
06-23-2016, 10:00 AM | #11 |
Active Member
Ready to restore
06-23-2016, 10:23 AM | #12 |
I found a really clean one, and it just showed up Tuesday. Thank you for the offer!
