09-30-2003, 07:57 PM | #1 |
Body Swap??
I am the new owner of Randy (teeitup's) big green machine. Just wondering how hard a full on body swap will be for me. I have access to a lift, and was wondering if i can leave the front clip attached to the cab and lift them off and back on at the same time?
It seems like it will be easy, but just want advice from those who have done it in the past. Thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
09-30-2003, 08:04 PM | #2 |
I think its easier to seperate the cab from the front clip. It won't be as bulky to lift off. The cab has four bolts holding it to the frame and the front has two. you need to remove the cowl to access bolts from the fenders to the cab. its really pretty easy to do. Good luck!
67 Chevy SWB - goal of a 1,000 hp weekend cruiser |
09-30-2003, 08:14 PM | #3 |
My other Love
put it this way, how many friends do you have? and how much are you willing to spend on beer. Use lots of penetration fluid, and strong friends and you should be able to get it done, without excess amounts of difficulty
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
09-30-2003, 10:04 PM | #4 |
i would like to do a frame off resto on a truck and also wonder how hard it is to do.
70 longbed 496/th400/Ford 9" |
09-30-2003, 11:14 PM | #5 |
its all about the +6 inches
Don't try to lift the cab and front clip. It will fold if you do. You could brace it, but by the time you got it all rigged up, you coulda done it the other way and had a few beers in you.
10-01-2003, 02:49 AM | #6 |
Resident Young Old Dude !
I have done this 6 times, Do it seperate...
Ron |
10-01-2003, 06:55 AM | #7 |
We have changed out the cab with the front clip on on three trucks and it worked very well. You will want to sling it and your fenders should be in good shape. We used two hoists.
Jim |
10-01-2003, 07:22 AM | #8 |
I guess I am a little different. I have done five K20 body swaps and I have left the doghouse attached to the cab on all of them. I'm getting ready to do another one here in the next few weeks. Anything can be done if you are careful. I'll take some pics when I do the next one here.
10-01-2003, 07:54 AM | #9 |
I did mine separately (disassembled the entire front clip), and it worked out well, but wish I'd done it all in one big chunk; doghouse and cab together because once I had the cab on the frame, and started piecing together, stuff just didn't line up like it did. Took me HOURS of frustration and Budweiser to get the lines looking good again.
Have some friends hold the front clip, and do it all at once. |
10-01-2003, 07:56 AM | #10 | |
10-01-2003, 08:34 AM | #11 |
CCRider
You only have to remove a few bolts to remove the front clip in one piece, saveing all the problems of linging the the stuff back up. I think it would be much easier that way
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
10-06-2003, 08:33 AM | #12 |
I just did another body swap Saturday. No problems and was finished in a matter of minutes leaving the front clip bolted on as usual. All I used was a chain hoist, nylon strap, 2X12 through the cab, welding vise grips, one ratchet strap and a sling. PM me if you have any questions on my redneck body swap procedure. I have more pics, but they are on my other camera.
10-06-2003, 08:34 AM | #13 |
another.
10-06-2003, 08:34 AM | #14 |
third
10-06-2003, 09:15 AM | #15 |
Dean,
Nice setup! Your pics show your setup real well. Jim |
10-06-2003, 11:25 AM | #16 |
Keep On Truckin'
Truck are a hell of a lot easier than unibody cars and are far simplier to work on.
You can just about bet you will end up spending more than you planned. I am in the middle of a frame off restoration and should have about $10K in it when done. This includes new motor, interior, paint, suspension and on and on. The only way to do one to this extent this cheap is to do most if not all of the work yourself and hunt around for deals on parts. Classic Industries just had a 20% sale that ended last month that provided great prices on quality items. Swap meets are also a good place to hunt for treasure.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
