06-07-2016, 01:26 AM | #1 |
headlight switch
have 73 gmc 350 v8 5.7l truck. when i replaced the knob rod into the headlight switch, the rod doesn't lock. i know when i took the knob rod out, you have to hold a spring type tab in the back of the switch to release it. it seems like i can't get the knob rod all the way in. Also is the slot for the knob keyed. thanks for any help. frank
06-07-2016, 05:12 AM | #2 |
Re: headlight switch
Yes, keyed. Has to fit into the dimmer portion so that when you spin the knob, the dash lights dim.
Try pushing the button while inserting?
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
06-07-2016, 11:52 AM | #3 |
Jay many thanks for the info. and quick response The switch works fine. frankyjoe 73 gmc c2500 3/4 ton 5.7 old granny.
