Old 06-07-2016, 03:48 PM   #1
Rust-O-Matic
Rust-O-Matic's Avatar
What is this switch next to my carb?
Dumb question... What is this switch for that was mounted to the intake on my small block next to the carburetor? It was was hooked to the throttle linkage with a piece of fine cable, which appeared to pull the switch closed at full throttle. The black wire attached to the switch in the pic was just grounded to the bolt holding the switch to the manifold. I don't get it. Any ideas?
Rust-O-Matic is offline   Reply With Quote
Old 06-07-2016, 03:55 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: What is this switch next to my carb?
Just a guess, but i'm thinking it could be something, like a passing gear for one of the old overdrive units.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-07-2016, 04:31 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
It's a newer throttle position switch mounted to an older transmission kick down switch bracket. The larger hole in the bracket was for this kind of switch:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-07-2016, 04:54 PM   #4
Rust-O-Matic
Any idea what transmission the switch was used on? Or more specifically, is this thing at all relevent to the turbo 400 that is in my pickup now? It kinda looks like some leftover crap from whatever vehicle the engine originally came out of. I believe it's a late 70s model (truck is a 66, and no idea if trans. is stock). I'm not familiar with how these switches are wired, but it didn't appear to be connected to anything except the bolt holding the bracket on.
Old 06-07-2016, 06:17 PM   #5
Fatherof3
Fatherof3's Avatar
Kills the tail lights at WOT for police evasion
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 06-07-2016, 06:20 PM   #6
Troy Sr
Troy Sr's Avatar
I think its for the Turbo400 kickdown or maybe NOS!!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 06-07-2016, 06:30 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep looks like the one I had on my TH400 for the 56.
Old 06-07-2016, 08:11 PM   #8
jtrichard
YES turbo 400 Has electric kick-down/passing gear that's what it is/was for
jtrichard is offline   Reply With Quote
Old 06-07-2016, 08:34 PM   #9
Blue666(2)
Talking Re: What is this switch next to my carb?
[QUOTE=Fatherof3;7618149]Kills the tail lights at WOT for police evasion
Yes, I need that switch!
.[Yes, I need that switch! /QUOTE]
Blue666(2) is offline   Reply With Quote
Old 06-07-2016, 09:08 PM   #10
Rust-O-Matic
Ha! I like your style, Fatherof3.
Thanks for the input, fellas. Looks like I'll be investigating my transmission to see what happened to the wire that's supposed to be connected to that switch. It probably hasn't been hooked up in years. I've only driven the truck on a couple mile long test rides as I've been working on it for several months, so I didn't even notice.
Just when a guy thinks he knows everything...
Old 06-08-2016, 12:51 AM   #11
frankslagoon
This is the switch on the stock 70 BB TH400. sure made a nicer trk when we put it back on the carb.
frankslagoon is offline   Reply With Quote
Old 06-08-2016, 03:13 AM   #12
PassengerTN
Strangely similar to the wide open throttle switch to engage the nitrous system on my old Mustang.
PassengerTN is offline   Reply With Quote
Old 06-08-2016, 09:00 AM   #13
DKO
That's hilarious! Thanks for a good laugh.
DKO is offline   Reply With Quote
