Old 06-07-2016, 06:43 PM   #1
jayoldschool
Moderator
Wrong master for dual swap?
Parts place sent me Cardone 10-1331 today for my dual master drum/drum no power brake upgrade on my 65 C10.
http://www.cardone.com/Products/Prod...oductId=101331
That looks like it's for the bigger C20/30 etc. Should I run it or send it back for a 10-1329?
jayoldschool is offline   Reply With Quote
Old 06-07-2016, 06:54 PM   #2
62stepside longbox
62stepside longbox's Avatar
Re: Wrong master for dual swap?
Is the bore size the same as the c10 master cyl? If so you should be fine
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-07-2016, 08:54 PM   #3
jayoldschool
Moderator
I don't know if the bore size is the same, but the brakes on the C20 are way bigger. The Cardone site doesn't state the bore sizes, but it lists the 1331 for the big brake trucks
The 62 C20 we're doing in the front, my 65 C10 in the back.
Old 06-08-2016, 11:14 PM   #4
jayoldschool
Moderator
Got a 1029 in today. Different than the 1031, I'll send that back. Getting all the adapters took my lunch time at the parts place, but I'm ready to bleed tomorrow!
