BlahBlahBlah
Swapping the front clip
So right now I have a 68 GMC clip on my K20. Im going to put a 72 Chevy front clip on it instead. I have all the correct sheet metal. Just need to know what I need to do to mount the new core support. Seems like the doughnuts and bolts are different ... or maybe they are different on 2 wheel to 4 wheel?
No real idea ... help a fella out ![]()
![]() Join Date: Dec 2013
Re: Swapping the front clip
Pretty sure all you have to do is drill the front core support mounts on the frame to accept the later model bushings on the 72 core support . East peasy !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
BlahBlahBlah
Does sound easy peasy, Ill have to contact one of the local vendors to get the correct core support mounts
you would need the 69-72 core support mounts.
i do believe the 68 gmc bumper is differnt than a 72 chev. also the outer brackets. front headlite harness. well you could use the gmc harness on a chev clip but it will take some modding to make the single 72 chev headlights work correctly. not to mention side marker lites that actually lite up on a 72. dont get me wrong i like the 71-2 grills but the gmc is so much less common. even with the slightly missmatched colors on your truck i would leave it be till i was ready too paint.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
I'm not positive , but I think the core support is the same at the mount area, as long as the mounts match the frame , 67-68 , or 69-72 , just re-use whatever core support mounts were there.
#6 | |
BlahBlahBlah
And looking at pics of a ton of 4x4s, and my last two, I really like the largeness of the 71/72 front on a 4x4. And I did forget about the harness, but I have boxes of harnesses, so Ill see what I have there.
#7 | |
![]() I wasn't sure if your clip still had a light side harness in it but I figured I would mention it. And I totally agree on the 71-2 grills they are sweet. It's just around here I really don't see gmc grills very often.
![]() Join Date: Sep 2007
got a pic of the GMC front clip? or are you not thinking of selling it
1967custom |
#9 | |
BlahBlahBlah
The GMC fenders and hood are the same as 67-68 Chevy and the core support is easily changed to Chevy, so Ill be keeping that too.
