Question to the past successful frame off restoration guys.
Approx. how much more money and time does it take to actually complete a project than you projected it would in the beginning? I have a 68 swb that I would love to dive into but it does need a lot of work and I know to fully enjoy driving it, I will need to upgrade the 3 spd manual to a 5, and of course 5 lug patter, air, power steering etc. From reading through build threads, several years to complete is not uncommon.
Re: Question to the past successful frame off restoration guys.
Always tough to determine the time, money it will take to complete a project, 2 yrs is a decent goal. Money, family, work, time. Good to keep busy, this is a hobby you can drive and enjoy. Also each build is unique, cost is what you want, need it to be. Probably 2k to get a basic no frills driver. My Blazer sat for almost 15 yrs before I got time and money to work on it....OH ....BTW.. its never done.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
I agree, its hard to say.
You got a couple of big projects already lined up. 5 speed is not going to be cheap. For the 5 lug conversion are you also looking to do disk brakes, etc. Are you doing the work yourself or paying a shop? Time is the hard part to predict. Other things always get in the way. I'm sure if I just worked on the truck, I could get it done quickly, but then there is soccer, birthday parties, weddings, life stuff, etc etc Are you also considering body work and paint into this project? |
Would love to do most all the work myself. Time is not a huge factor as long as I make steady progress. What I hate is when I get off a project for 3 - 6 months. Really hard for me to get back motivated and involved again. These guys that take 5 years to finish after going through several extended "time away" periods really amaze me. They have my full respect.
I would get it running as is 1st, Make it safe, check brakes, tires etc, then clean it up, There are 6 lug disc brake kits, I like the wheels. Not knowing your skills etc, Then jump on an upgrade you want to tackle 1 at a time, You get to drive it and the down time is manageable. Just my 2 cents.
#6 | |
![]() Join Date: Mar 2011
Ive done a few resto's before this one on my truck--so I thought I knew what to expect. This truck was my first "Every nut, bolt and screw" resto.
I honestly don't know where Im at on money spent. I do know Im way over budget and my initial goal on a time frame was no more than two years. Im currently in my fourth year. With luck Ill have it done by early fall (this year!!) Life does have a way of getting in the way of finishing your project. If you have to allocate funds for the truck on a month to month basis, my recommendation would be to Not start a major resto. Instead, make a list of several smaller projects, prioritize them under "Need to do" and "Want to do", and when figuring your budget--always figure "worst case" rather than best case. I absolutely amazed myself on how badly I misfigured this project. Even though I don't have an accurate accounting of costs so far--I do have every receipt and some day (when Im finished), Ill do the final accounting. I am relatively sure that Im hovering around Double of my original estimate on cost. My link to my build thread is here, if you read it you can get an idea how things can balloon .
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
It all depends on what you want out of your truck. I planned and planned and planned some more on my build. And no matter how much you plan, in the end there will always be something that you didnt budget for. I thought I could build a truck ground up (LS, PB fab suspension) for roughly $30k. Best of a lot of parts not skipping any corners. I blew right past that budget with a lot more left to spend :/ As far as a timeline, thats a hard question to answer. My biggest problem with a frame off is that it is so easy to get overwhelmed. Every now and then I get discouraged with mine, and I simply take a step back from it for a little bit. Just remember, building trucks is supposed to be as fun as driving them. Don't put a lot of pressure on yourself by creating a time frame and feeling under the gun to try to meet it. Thats how corners get cut and mistakes get made.
#9 | |
[QUOTE=shores6;7620255]It all depends on what you want out of your truck. I planned and planned and planned some more on my build. And no matter how much you plan, in the end there will always be something that you didnt budget for. I thought I could build a truck ground up (LS, PB fab suspension) for roughly $30k. Best of a lot of parts not skipping any corners. I blew right past that budget with a lot more left to spend :/ As far as a timeline, thats a hard question to answer. My biggest problem with a frame off is that it is so easy to get overwhelmed. Every now and then I get discouraged with mine, and I simply take a step back from it for a little bit. Just remember, building trucks is supposed to be as fun as driving them. Don't put a lot of pressure on yourself by creating a time frame and feeling under the gun to try to meet it. Thats how corners get cut and mistakes get made.[/QUOTE
Thank you for your reply. Yes your right, the build does need to be fun. Your post has been very helpful and much appreciated. The more I read and learn, the more I am convinced that this particular truck is not right for me to invest the time and money into for a full restoration. Had it been my grandfathers and we used to go fishing together in it, yeah that would be different. |
![]() Join Date: Jun 2009
I feel each build is unique in its own way, more often than not plans change part way through also. I started my build in 09 and it is still a frame sitting in the building. I have bought a number of parts right here through the forum and also a number of parts on craigslist. I am now close to having enough parts to make it a rolling chassis
By the way it looks like a great start you have there. I like it !!
