Old 06-08-2016, 12:53 PM   #1
1968BURBAN
Tailgate questions and rear sill
Looking for some direction on either rebuilding my tailgate hinges or buying new. I havent seen anything in any of my catalogs for a pin and bushing kit.
Any help would be greatly appreciated
Last edited by LockDoc; 06-08-2016 at 10:58 PM. Reason: Need to be a premium member to post a "want to buy"
1968BURBAN is offline   Reply With Quote
Old 06-08-2016, 09:13 PM   #2
Franks 72
Active Member
Franks 72's Avatar
Re: Tailgate questions and rear sill
I had a similar problem (barn door application but I suspect construction method is the same) The rear tail pan is a complex piece to repair but can be done. Mine was paper thin with rust. I removed it completly and drilled all spot welds which hold the "cover" and made new pieces with a brake and welded up new assembly .The result was not ideal cosmetically since the spot welds in the cover are now plug welds and ground smooth, but it is stronger than what was there . Probably best to try and find someone parting out. If the tailpan is rusty , check the main crossmember for corrosion. It may be paper thin also but harder to see ! Hope this helps!
Franks 72 is offline   Reply With Quote
