Axle Bolt Sizes?
I am having a little problem finding the correct size of axle bolts. So far all Auto Parts have only up to 1/2" dia. of the bolt. I have measured mine and its 8" tall x 4 1/8" center to center x 3/4" w/16 TPI. bolt, I want to lower it and need new u-bolts but all i come up with is a 1/2" bolt. I also called The Truck Shop and was on hold for 15 min. "NOT LOL". I guess its par for the course there.
Can any body tell me if what I have is correct for a **68 C10 coils all 4 & trailing arms**. thanks in advance Last edited by ck5566; 06-08-2016 at 08:01 PM. |
#2 | |
Re: Axle Bolt Sizes?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#3 | |
Still looking for correct answer for the correct size of u-bolts for a 68 C10 coils all 4 corners with trailing arms. Last edited by ck5566; 06-09-2016 at 12:51 AM. |
Auto parts stores don't carry U-bolts that big, as you found out. If you look in any of the online catalogs for 67-72 trucks, you will find them. If you want to lower the truck, you will need longer than stock bolts and a set of lowering blocks. There was a guy on the forum here that sold those.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
![]() ![]() Join Date: Jan 2015
Check with your local spring shop they will have all sorts of diameter bolts and can make them any length you need in square or U-shape
#6 | |
I second that. And they will be of better quality since they actually use what they make and sell.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
This should be what you're looking for. http://www.classicparts.com/mobile/1.../#.V1rq-ellDqA
You can call and make sure at 1-800-741-1678 |
#9 | |
#12 | |
